NEED DRUMS - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-05-2002, 08:45 PM
johnnymopar's Avatar
Love your nails! You must be a Libra
Post NEED DRUMS
i'm working on a '55 chev pickup on the side. there is a 10bolt rearend on there with no drums. what is the easiest way to find out what drums i need? can i measure the backplate, shoe depth and bolt pattern? any ideas?
thanks,
JB
"Well done is better than well said." - Benjamin Franklin (1706-1790)
Old 11-07-2002, 10:56 AM
New Member
Post
You will need bolt pattern, shoe diameter, shoe width, the distance from the flange for the wheel to the backing plate, and luck. Ask the parts store or junkyard people if you can try it out for size and return if needed. It's a place to start.
