Need a dyno estimate pleaseeeee! - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-14-2012, 02:03 PM
hey my name is nathan mcquaid. i'm 22 years old and i have a 1987 gmc s15. i just finished putting it back together after a year overhaul, including a new paint job, motor swap and completly stripped down the interior. I was wondering if anyone could give me a rough estimate of horse power/torque and even throw out some 1/4mile times, as i have not been able to take it to the track yet.
Engine is:
350 cubic inch,
BLOCK CASTING NUMBER 3970010
CAST CRANK, LARGE JOURNAL
(OLIVER) 6" CONNECTING RODS - FORGED STEEL WITH (ARP) BOLTS
(WISECO)? PISTONS 6166A4 FORGED ALUMINUM FLAT TOPS - 2 VALVE NOTCHES - .927 PIN - SIDE HEIGHT 2.07"
(MELLINGS) M55HV HIGH VOLUME OIL PUMP
BALANCER 3896966
compcams extreme energy hydraulic roller cam- .502/.510 lift 10 centerlines
edelbrock performer rpm aluminum heads 2.02
edelbrock performer rpm high rise intake
holley 750 mechanical
headers are 1 5/8 hedman longtube 3'' connectors
Transmission is:
700R4 with stage 2 shift kit, 2800 stall
truck has ladder bar setup with coilovers, rear end is ford 9'' with 355 gears, mini spool. truck will be run with slicks i think theyre29/10.5/15
if anyone can do me up a virtual dyno i would really appreciate it and give me some 1/4 mile times and any other pointers i'd love to see this truck do low 12's. thanks for your time.
Old 07-14-2012, 04:51 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
The member who used to do most of these has left the building. You can download programs, and use some online free ones, Google it.
Semper Fi
Old 07-14-2012, 08:17 PM
vinniekq2's Avatar
guess
maybe 400 HP ish
350, s15
Engine dyno to chassis dyno numbers dedub Engine 3 06-19-2011 07:56 PM
HP Estimate? Dyno Simulator Help. Landshark928 Hotrodding Basics 4 12-03-2010 12:41 PM
Anyone with Desktop Dyno? Power estimate on 383 Vortec? The Fiddle Hotrodding Basics 0 11-02-2010 09:26 PM
desktop dyno & 1/4 mile estimate PLEASE!! 66 T-Bird Engine 2 05-25-2006 03:55 PM
Can someone give me a rough Dyno estimate? leastbay Hotrodding Basics 8 06-03-2004 12:41 PM
