need elec fuel pump for RV - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-05-2010, 04:35 PM
OK my brother in law just got himself a 1982, 32 footer. the previous owners had to replace one of the pumps. they could not find the right one so just put something up there. as long as your in town its fine as soon as you hit the highway, she will start stuttering from low fuel. so we need a fuel pump that will give us enough fuel. he don't need a super race type pump. just something Strong enough to give us the fuel we need that also will not need a regulator. it has a 454
Old 06-05-2010, 04:59 PM
DoubleVision's Avatar
The standard carter electric pumps always worked for me. However, chances are to get a pump to feed the monster, you`ll be left with no choice but to run a regulator. The carter street pump says it runs 5 psi max, but when I got mine it ran 9 psi so I had to get a regulator. Even so I`m sure you already know but it don`t hurt to mention mount the pump close to the tank as possible.
Old 06-05-2010, 05:40 PM
techinspector1's Avatar
Wiki Edits: 326
Tee off at the carb inlet and run a line up to the cowl where you will mount a 0-15 mechanical fuel pressure gauge that you can monitor through the windshield. Just mount the gauge however, with tie wraps and duct tape. It's only temporary until you get the pressure dialed in. 5 psi max for an AFB type carb, 6 psi max for a Holley. Until you do this, you'll just be guessing and howling at the moon.
Old 06-05-2010, 05:48 PM
I'm not sure were th pump is ant looked yet, but the factory pump was elect but no one can find a replacement. I'm assuming the 40 buck carters is what is on there now. i just can seem to talk him into just driving 45 on the hgwy
Old 06-05-2010, 07:44 PM
like i said i have not seen it. it is stock so im sure its a qjet. it does have anther pump that works fine for the second tank. the PO told him when it was replaced they could not find the corect pump even at the dealership.
we are trying to stay under a 100 bucks.
i have just thought about just sending the fuel to the tank that works. its only going to be driven once every 2 to 3 months to get to the next job sight.
what would yall do if it were yours. just to make it run right
Old 06-05-2010, 09:42 PM
Wiki Edits: 326
What would yall do if it were yours?
See post #3. 5 psi for a Q-Jet.
Ford 1 and 2 piece fuel pump eccentrics lluciano77 Engine 34 06-12-2014 04:27 PM
fuel pump failed during carb overhaul?! pcoghlan Engine 5 02-22-2009 09:44 AM
changed fuel pump from mech to elec - HELP! junkyard junkie Engine 16 09-19-2007 07:30 PM
'53 Buick Special - Convert to Elec Fuel Pump? [NFBS]Flash General Rodding Tech 2 12-11-2005 05:58 PM
Electric fuel pump bad or not? HotRodMan Electrical 4 09-10-2005 09:47 PM
