Need electrical help
I just finished some up-grades to my wiring on my old 23 T bucket. Nowit will not start. The following are the issues I am encountering and would ask for help trying to solve them:
* The motor turns over just fine. * I am getting power through the ballast resister to the coil (both the positive and negative side of the coil). * However, I am not getting any spark from the coil wire to the distributor. I have held the coil wire away from the engine block while cranking the engine and am getting no spark from the coil. I'm certainly not an electrical person and I'm hoping it is something simple I can do to correct it. Thanks for your help, Jim |
Hi Jim, Welcome to the site
If you post this in the electrical section someone will help you out, The Intro section not everyone will check it. Cole |
Moving this thread to electrical
Sounds to me like your points are not set correctly....if it has points
Ontario Rodders |
Does it still have a point distributer in it now ? Or what type distributer set-up do you have in it?
Cole |
Cole |
| help with electrical | Smokeytires | Engine | 1 | 10-30-2009 08:49 PM |
| MAD Electrical | jimmmy | Electrical | 26 | 02-06-2008 09:18 PM |
| electrical | 42chick | Electrical | 11 | 01-24-2008 07:59 AM |
| Electrical | knumbskull | Electrical | 5 | 08-11-2003 05:31 PM |
| ELECTRICAL | JTOREGRASE | Electrical | 0 | 04-21-2003 06:51 PM |
