Need electrical help
I need a little electrical help. The electric fan will not kick on or off even with a new relay. I tried 2 or 3. Anyway, the hot wire is hot, the ground wire works, and the other hot line out of the relay is hot all the way to the fan. The green wire when grounded will turn on the fan but it wont turn off becuase it is always grounded.
Now, Im guessing that the coolant switch grounds that green wire to the relay when it reaches a certain temperature to kick on the fan. So, do you think I need a new coolant temp sensor or what? Thats what I'm thinking, what do you all think? |
Relay
Doc here,
The right way to wire the relay should be...
That'll get 'er done! If it's wired that way, and it still won't function, suspect a bad ground OR a faulty sender...If it was a stock system that ran fine before, I'd suspect the sender.. With it dead cold measure with an ohm meter to ground from the sender wire , it should be infinite..or open...then start the car, as it warms up to temp the reading should drop to 000 if it's working. If it dosn't get a new sender...If it does, look for a bad motor ground. Doc
Aftermarket Solutions Electronic & Electrical Innovations Last edited by docvette; 05-18-2005 at 07:11 PM. Reason: afterthought |
Ok, thanks for the help. I just needed reassurance that I was thinking right, lol.
| Electrical Advice | willowbilly3 | Electrical | 25 | 12-26-2004 10:11 AM |
| 42 volt automotive electrical systems | hoodoo | Hotrodders' Lounge | 2 | 10-31-2004 04:35 PM |
| Cleaning electrical contacts | Kevin45 | Electrical | 0 | 01-05-2003 09:22 AM |
| Electrical Services and New Website | Sparky_wp | Electrical | 0 | 12-19-2002 09:25 AM |
