need to find out the year of a 350 chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-02-2013, 01:16 AM
The numbers from the front of the engine are 1m1117 7h04
Old 05-02-2013, 03:15 AM
DoubleVision's Avatar
If your referring to the stamping on the front passengers side deck then the
"M" stands for GM of Mexico, which means it's more than likely a target master replacement engine. To get the date of the engine you'll need to look on the rear on the bell housing flange. On the rear drivers side the casting number is there, the casting number tells us what it is and the years it was produced.
Also on the bell housing flange will be a date code which will look like this example:
C 23 9
C is the month. C is third in alphabet so third month = March.
23 is the Date = The 23rd of march
The 9 is the year = 1959, 69, 79, 89, 99.
The casting number tells us what years that casting number was used, so if the casting number indicates the block was made from 1970 to 1980 we know it's a 1979 block.
The Following User Says Thank You to DoubleVision For This Useful Post:
pw1961 (05-02-2013)
Old 05-08-2013, 09:11 AM
chevy 350 date of block
The numbers on the back of the block are 10066036
Old 05-08-2013, 09:15 AM
vinniekq2's Avatar
double vision posted on your last thread:
C 23 9
Old 05-09-2013, 12:44 AM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Your firs thread of the same issue has been merged here. Please do not double post.
Semper Fi
Old 05-10-2013, 07:04 PM
10066036 is an 86 up 350, 205hp, a car & Truck 2 & 4-bolt manual passenger engine with 1pc RMS
what year is this chevy 350? addictivewoodworks Engine 3 03-07-2012 06:06 PM
need to know the year and info on my chevy 350 engine theapehanger98 Engine 3 10-20-2011 10:49 AM
Chevy 350 Hissing Under load, can't find it Leviticus Engine 2 03-22-2010 12:47 AM
What year is my 350 Chevy motor? starneyboy Engine 2 03-02-2007 02:51 PM
Where Can I Find Info On Vacume A 350 Chevy SBC Engine 15 11-11-2006 05:47 PM
