Need Flexplate Help Please - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 06-02-2011, 02:45 PM
chevyrestore's Avatar
after driving a little while when I start off from a dead stop it seems like it hesitates before moving. The best way I can describe it is I press the gas...it thinks about going, then 1/2 a second later it goes, sorry its really hard to explain...any ideas?
  #32 (permalink)
Old 06-02-2011, 02:51 PM
SSedan64's Avatar
Make sure the TV cable is adjusted correctly. Fluid level correct?
Sounds like a low pressure problem. I wouldn't drive it until you find the cause/problem. Can quickly smoke the Clutches.
A Pressure test is also a good idea.
http://www.jakesperformance.com/TV_C...etup_Info.html
  #33 (permalink)
Old 06-02-2011, 02:53 PM
fluid level is correct, if it is a cable adjustment issue would that hesitation point to a cable too loose or a cable too tight?
  #34 (permalink)
Old 06-02-2011, 03:04 PM
SSedan64's Avatar
Cable loose= low pressure & soft shifts.
Cable tight= higher Pr. & firmer shifts.
Seal on Filter neck in the pan leaking or Filter not installed correctly can cause low Pressure.
Pump wear will also cause low Pr.
  #35 (permalink)
Old 06-02-2011, 07:09 PM
tnsmith10's Avatar
when will it rain???
that more than likely is carb related, not trans. does the rpm come up and then the trans decides to go? or does the engine just go flat for a second then accelerate?
  #36 (permalink)
Old 06-02-2011, 07:15 PM
seems to go flat for a split second and then move. It will not do that in park, only when trying to move the truck.
  #37 (permalink)
Old 06-05-2011, 06:59 PM
any suggestions? I did change the linkage on the carb to the top hole and it seemed to help a super super tiny bit FYI. Could timing cause this?
  #38 (permalink)
Old 06-05-2011, 07:05 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Still can be the carb IMHO when it's in park it's not under a load and when you drop it in gear it is. JMO
Cole
  #39 (permalink)
so what adjustments should be done to the carb?
  #40 (permalink)
Old 06-05-2011, 07:14 PM
eloc431962's Avatar
Wiki Edits: 37
I don't know what carb you have but here is a link that can help with a holley carb. you need to check the float levels and the air fuel mix and also check for any vacuum leaks. And if you have a good light it wouldn't hurt to re-check and see where the timing is at. JMO .http://www.holley.com/TechService/Library.asp .
Cole
  #41 (permalink)
Old 06-05-2011, 07:51 PM
I just had the air/fuel mixture set a week before I replaced the trans/converter and they set the timing to 0 degrees they said. Its an edelbrock performer carb and there are no vacuum leaks I can find.
  #42 (permalink)
Old 06-08-2011, 10:09 PM
I figured out today that after I adjusted the float level on that bracket it got a little better but only first thing in the morning. It seems when the engine heats up the hesitation happens and also when that is happening if I put it in park and rev the engine it sputters a tiny bit the very second I push the pedal until it gets to around 1100rpm or higher. Any suggestions or should I take it back to the carb shop that adjusted it?
  #43 (permalink)
Old 06-08-2011, 11:09 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
It needs more timing unless this is using the OEM computer that requires the timing to be set at 0 degrees w/the tan/bk stripe timing bypass wire disconnected.
If you have a normal non computer controlled ignition, set the timing to 10 degrees BTDC to start with. Be sure the total timing isn't too high else the distributor will need modifying.
  #44 (permalink)
Old 06-09-2011, 12:12 PM
its non computer controlled and if I adjust the timing from 0 degrees to 10 degress BTDC will the carb air/fuel mixture need to be readjusted again or will that not be affected?
  #45 (permalink)
Old 06-09-2011, 01:01 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Advancing the timing won't require any internal changes to the carb, providing that the carb was set up correctly to begin with.
Any time the timing is changed, it is a good practice to go ahead and check/readjust the air/fuel mixture screws to give the best idle speed/highest idle vacuum.
Just increasing the timing from "0" to 10 degrees BTDC will increase the idle speed and vacuum, so I would expect that after setting the timing you will then need to lower the idle speed, using the curb idle speed screw. Then readjust the air/fuel mixture screws to give you the highest idle speed/highest vacuum reading, then adjust the curb idle speed again if needed, in order to keep the idle RPM where it should be.
Flexplate crash Engine 3 07-17-2009 05:59 PM
Flexplate JDracing57 Transmission - Rearend 5 11-03-2008 02:44 PM
5.7 flexplate 47 Coupe Engine 1 02-01-2008 03:39 PM
which way does the flexplate go on? malibu68 Engine 17 04-02-2007 06:51 AM
Flexplate is a flexplate? theclaw1 Transmission - Rearend 1 05-04-2005 09:54 PM
