Need Flywheel bolt pattern diameter... - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-16-2005, 09:57 PM
can someone measure off a small block chevy ..the diameter between the flywheel bolts... doesn't need to be spot on but close if poss.
just measure straight across between two bolts hole center as pictured ..
I'll be thankin ya!.. close is fine
seems like the pre 85 flange pattern is larger than the post 85=86.. can anyone conirm that?
bennett
Old 10-17-2005, 08:49 PM
According to Scoggin-Dickey's website, the old pattern is 3.58", and the new one is 3.00".
http://www.sdpc2000.com/catalog/3181...-168-tooth.htm
bolt pattern changing jniolon Body - Exterior 6 08-01-2005 01:02 PM
do these two carbs have the same bolt pattern bigwildgrin Engine 2 06-05-2005 03:45 PM
bolt pattern for ramcharger 74huggerorange Suspension - Brakes - Steering 2 05-30-2003 12:00 PM
Bronco wheel bolt pattern? Seon General Rodding Tech 2 05-15-2003 04:39 PM
lug bolt pattern and such 5.0Towncar Hotrodders' Lounge 3 11-18-2002 09:02 AM
