Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Ford engine questions. Small block Ford
Old 12-03-2012, 09:42 PM
hcompton's Avatar
hcompton hcompton is online now
Old & Furious
Originally Posted by Hookedup12 View Post
Would it be worth time to get a custom grind cam since there not crazy expensive or just save money for another thing
Well you may have a good cam right now until its in the car i would not mess with it.
10:1 cr is good and 7 k rpm sounds pretty good. Think it will do the trick. Cr is way to high for blower without changing the pistons. A little joice and your done. Run it and save your pennies for a big block.
I am a full on chevy guy so i know what i would stick in it. But my friends usally talk me out of the fords i come across before i get a chance to put a chevy motor in them. But i would be happy with what you got. Light car high rev engine and good compression. Should be very nice. You must have thought about it to much while it was in the garage must be time to put it in the car.
