Need Frame Advice/HELP for my 1957 Chevy Truck - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-06-2009, 12:15 PM
Paul Manno
So I picked up a 1957 CHEVY PICKUP-
1 TON
LONG BED (Step Side)
Big Back Window
I'd like to put it on a newer, more updated frame... Also, I need to update the wiring as well... I heard S10 frames can work...
But I need a 123" wheel base... any advice would be greatly appreciated. !!
Old 05-06-2009, 01:55 PM
tmeyer's Avatar
Livinthedream57, I have a short bed 57 pickup which I was going thru the same process you are about 3 yrs ago. I decided to graph a generation 2 camaro clip into my original frame. I rebuild everything in the front and installed 1" lowering 400 # springs. I also when with a mid 85's Iroc Z steering box. This went very well and I believe this truck is going to handle great with the spring upgrade, new bushing, and a 1 1/8 inch sway bar.
If I were in your shoes, I would shorten your bed and frame to be a short bed. Just a thought. Good luck and have fun working on it. Lastly, keep us informed on what you decide to do with updates along the way.
Tom
p.s. Here is a link to pics of my truck.
http://www.meyerbrosrods.com/photos/...k/default.aspx
Old 05-06-2009, 07:51 PM
Paul Manno
I heard that some people had a hard time with grafting front clips on... and it may be a little too complex for me... hence why i was pondering just doing a direct frame swap... ANY IDEAS for a whole frame
frame swap for 1950 chevy truck truck1950 Hotrodding Basics 39 06-24-2015 03:40 PM
1953 Chevy Truck Vin Help Homeseller Hotrodding Basics 14 08-12-2012 10:24 AM
1957 Chevy truck gerdis00 Suspension - Brakes - Steering 6 04-20-2008 12:00 PM
1934 Chevy Master Frame mistermuscles General Rodding Tech 4 01-14-2005 01:50 PM
66 chevy truck frame swapping ezoo Suspension - Brakes - Steering 9 01-13-2003 05:58 AM
