need gear ratio - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2011, 05:41 PM
Buckeye Bob's Avatar
need gear ratio
my friend just called me & ask me if i could find out what his gear ratio is
he said that the tag was 3.10 he has a 59 ford retracktable with a v8
what can i tell him
Old 11-17-2011, 05:49 PM
gmc1990rodder's Avatar
what can i tell him
Tell him that unless someone has changed the rearend he has a 3.10 gear ratio!!
Old 11-17-2011, 06:17 PM
EMWOLBS 23t's Avatar
only other way that he can check without pulling cover or rearend is to spin the rear wheel one complete revolution and count driveshaft revolutions that will give you a good indication as to what it is ,,three complete rev,of the driveshaft and a little past it to one complete spin of the rear tire will tell you if it is a 310 ?? old school ????
Old 11-19-2011, 06:14 PM
310 rear
how good of a rear is that 3:10 ? my friend is puting a 5.0 w/aod in his 59 retracktable
Old 11-19-2011, 06:45 PM
35terraplane's Avatar
Need gear ratio
Not very good with the AOD. he should have around 3.7 or up.
Bob
Old 11-20-2011, 02:46 PM
user151's Avatar
If you jack up one wheel, you must turn it two times, and count the driveshaft revolutions.
I'm assuming it's not a locker or limited slip...
Old 11-20-2011, 06:35 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
what can i tell him
The tag indicates it's a 3.10:1 ratio. But things sometimes get changed through the years and so to be sure you need to check the ratio.
Old 11-20-2011, 06:40 PM
Wiki Edits: 49
Should be a Ford 9" rear which is practically indestructible. I'm guessing it is an open rear (non posi) so what user151 says is the correct way to check the gear ratio. The best way is to jack up the passenger's rear tire (right rear) since that is the drive wheel, and make sure you have some sort of chalks holding the front tires so the car won't roll off the jack. With the trans in neutral rotate the tire twice and count the driveshaft rotations. That will give you the ratio. If he can't turn the wheel at all or if it is very difficult to turn he might have a posi rear, in which case you'll need to jack up both rear wheels and turn either wheel one revolution to get the gear ratio. I'm guessing since the tag is still there it has the stock 3.10 gear set which as has been mentioned is a little tall for an overdrive trans, however he can have the gear set changed to something a little more OD friendly pretty easily.
Centerline
HotRodsAndHemis.com
The most important things you learn are those things you learn AFTER you know it all. -- Chip Foose
Richmond Gear 5-speed,Why all the first gear ratio options? Argess Transmission - Rearend 1 10-17-2011 07:11 AM
what gear ratio hman17024 Transmission - Rearend 3 08-16-2011 11:52 PM
what gear ratio weekend warrior Transmission - Rearend 1 10-25-2010 05:32 PM
Rear end gear ratio change = spedo. cable gear change. help? turbo 350 sugar ray Transmission - Rearend 6 07-18-2007 11:32 AM
gear ratio chev kev Transmission - Rearend 2 01-10-2005 01:48 AM
