Need Gm posi info - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-11-2005, 01:44 AM
Need Gm posi info
I read somewhere:when looking for posi. rears ; check station wagons. I did and the first Chevy 86 had one. Of course its probably a highway gear so can the posi be taken out and used with better gears 342, 373 etc? I dont know much about different series. So how do you go about using these posi. units from cars with high ratio highway gears? Are they worth getting out of these cars? I think they are 8.5 rears but Id have to look again to see; its been a while since I crawled under there. If it can be used , I know Ill have to get the gear set I want and have someone install , set up gears. thanks
Old 12-11-2005, 02:21 AM
If it's an 8.5" posi unit, the carrier should have either 410408N or 410409N cast into it. 410408N is used with 2.73 and numerically higher gears, and is known as the 3-series carrier. The other is for the lower gears (2.41, etc.), and is called the 2-series carrier.
Posi not Disengaging gt2betubbed Transmission - Rearend 4 02-18-2004 10:23 PM
seeking info about posi track digitalfrek Transmission - Rearend 10 02-03-2004 05:36 PM
8.5 GM 10 bolt posi musky2 Transmission - Rearend 1 12-25-2003 10:57 PM
GM 10 Bolt Diff w/ Auburn Posi k6qk Transmission - Rearend 10 12-17-2003 07:45 PM
