Need good radiator hose sealer - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2005, 01:58 PM
cboy's Avatar
Last journal entry: Finished
I can't seem to get a water tight seal on the top radiator hose of the rat project. This is the point at which the top hose attaches to the 1 1/2 copper pipe which then runs to the rear mounted radiator. I think the problem is that the copper pipe has no "lip" or "ridge" at the end for the hose clamp to seal against. It's just too smooth. I've tried double clamping it as well as trying Permatex High temp RTV silicone and Rutland high heat silicone. The bottom hose seems to have sealed okay (at least for the moment) with just a simple clamp but the top one just won't stop leaking. Any ideas?
Dewey
Always learning...and sharing what I've learned.
Old 06-27-2005, 02:03 PM
NXS's Avatar
NXS NXS is offline
wind & fire = guides to power
1st, ditch the silicone. Use some 80 grit sandpaper to ruff the copper up and clean and rough the hose up on the inside so fresh rubber with no silicone can make contact.
Are the hoses the same size or is the rubber hose too big?
Old 06-27-2005, 02:29 PM
RCastle's Avatar
Come Home Safe Soldier
Last journal entry: Headers
A T-Bolt is a good style clamp and should help with your proble.They have a large pressure area and do not look bad either.Actually they look and seal alot better than conventional worm gear style clamps.Check the T-Bolt style
Old 06-27-2005, 08:11 PM
edge's Avatar
Time is short, are you ready?
Copper Pipe with No Lip:
Solder on a ridge like Willys36 did:
Go down to entry #131
Best of luck, Ed. www.edgesz28.com
Old 06-28-2005, 07:00 AM
cboy's Avatar
Thanks guys. I'm off to the shop to try those tips. And Edge, I should have remembered that trick Willys used. I read those entries in his journal 3-4 times. I think my brain must be dropping off from 12 volts to 6 volts.
Maaco vs. At-Home Paint Job nightrain_rod Body - Exterior 127 08-26-2012 03:07 AM
Good Sound Thom Laybourne Interior 6 03-18-2004 12:56 PM
GOOD REAR END SETUP FOR A 68 CHEVY TRUCK erik350 Transmission - Rearend 1 05-14-2003 07:35 AM
Good price???? HemmiGremmie Hotrodders' Lounge 4 01-06-2003 04:30 AM
where can i get a good paint integra_2222 Body - Exterior 3 07-29-2002 06:21 AM
