Need guidance - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-29-2013, 11:04 PM
vinniekq2's Avatar
If you buy aluminum oval port heads,mild hydraulic roller cam,victor junior oval port intake,850 Holley,Im sure that would work.
now 500 - 600 is a big range,pick a number or performance goal,IE:mid 11s in a 77 Camaro with auto weighing 3800 pounds with driver and we can nail a formula
  #17 (permalink)
Old 03-29-2013, 11:11 PM
vinniekq2's Avatar
120325-12 NA 282 288 229 235 .589 .600 112 108 Hyd. Hyd. 1,2
2000-5800 Fair idle, Moderate Street/Mild Bracket. Good mid range. 10.0-11.5:1, 2500+ stall.
a cam like this
AFR,265 cc oval port heads ( or equal)
with previously mentioned parts= tire shredder
  #18 (permalink)
Old 03-29-2013, 11:13 PM
11s would be sweet it's a 71 gmc 1500 auto not sure of weight But I'd like 11s or better but I'd also like to be able to drive it around town.
  #19 (permalink)
Old 03-29-2013, 11:14 PM
I have no idea what all those numbers mean sorry it's all new
  #20 (permalink)
Old 03-29-2013, 11:27 PM
vinniekq2's Avatar
quick translation for cam specs
600 lift
hydraulic roller( use a solid roller if you rev higher)
108 intake center line
112 lobe separation angle
229 intake duration at .050
235 exhaust duration at .050
power band from 2-6000 RPM red line
compatible with 10:1 CR
  #21 (permalink)
Old 03-29-2013, 11:28 PM
vinniekq2's Avatar
ya I heard Canada has 94 octane fuel at chevron,with zero methanol
  #22 (permalink)
Old 03-29-2013, 11:32 PM
I should be able to take those numbers to a shop and they can get the cam and parts you listed thank you very much for your time and help its much appreciated.
Here Iam!!!! and looking for guidance! inuke Introduce Yourself 1 01-28-2009 10:28 PM
Need Guidance Please !!!!!! "70" Cougar Hotrodders' Lounge 2 04-15-2008 08:00 AM
Need some guidance cameano Engine 5 08-30-2006 01:13 AM
Need some Guidance 36ford3window Body - Exterior 4 05-06-2006 10:31 AM
Looking for some guidance likestotinker Engine 2 07-25-2005 06:56 PM
