it should be, but i dont think i would use the stock rotating assembly. i would bore it to 4.500 and use a 4.250 forged crank to make the 540. on a decent rotating assembly and the machine work to the block and balancing you can expect to spend around 2500.00. find a set of used alm heads and have them cleaned up and rebuilt by a good performance shop, this should save you about 500-600 on the price for a brand new set. find a used rebuilt carb and intake, this should save you anther 300-400. right there you have saved 800-1000 so far. get an idea of exactly what motor you would like to build and then start looking for used parts off of one of the sites that i mentioned, if you ask i'm sure some others on here know of some other good sites to check out for used parts too. |
oh for sure, but you dont have to spend $9000 on a 540 either, the only reason a 540 would cost more would be because you were buying a 502 block which shoudn't cost much more than a 454 block, maybe i can see you spending 50-100 more on it, and then the forged 4.250 crank which a budget freindly 4.250" forged crank can be had for 600-800.00 here are some prices straight out of comp products: street/strip rotating assy cast steel crank, forged pistons, scat 4340 I beams -pn SS468F 468cid = 1159.95 -pn SS540F 540cid = 1249.95 (now i didn't think they made 4.250 cast steel cranks though so this one is a little strange) value series race assemblies, 5140/4130 froged crank, forged pisonts, scat 4340 I beams (they dont have the 454, only 496 and 540) -pn BR540D 540cid = 1479.95 now for what i would actually use if i were building it sportsman race assemblies, 4340 forged crank, forged pistons, 4340 H beams -pn SR468D 468cid = 1699.95 -pn SR540D 540cid = 1729.95 neither of the 540 kits cost more than 100.00 more than the 454 counter part and all the clearancing that needs to be done can be done by him with a neumatic grinder. you might need a stroker pan and you would need some heads that flow a bit more but you wont spend that much more on a 540 than you would a 454, and the additional cost will more than make up for it's self |
No need to waste money on a rotating assembly when what is already there is a good starting point. Can the stock pistons and replace them with good light forgings- SRP, Mahle, Wiseco, Ross, etc. Even KB/ICON forged (NO HYPERS) |
that's right i forgot that the 502 has a 5140 4.000" forged crank, they aren't quite as strong but like mentioned it will do |
| 383 engine tapping and oil burning- weird | RowShan | Engine | 15 | 10-10-2009 05:07 PM |
| Building a 400 b drag engine, need some advise | Kmontgomery | Engine | 5 | 08-31-2009 07:50 AM |
| Low compression Engine. Can I make some power? | Deezildennis | Engine | 7 | 02-02-2008 06:08 AM |
| Engine Knock at low RPM | Paco | Engine | 8 | 08-19-2002 06:12 PM |
| help on building low budget 350 | 85irocss | Engine | 6 | 06-12-2002 07:04 PM |
