need help with 04 speedo questions - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-27-2008, 10:35 PM
i have an 04 chevy 1/2 ton p/u. the speedo is stuck on 125mph. i have no idea why. i bought the truck used about 5 months ago everything worked fine untill now. the check engine light is not on. eveything else seems to be working ok. can anyone help
Old 03-28-2008, 07:27 AM
Holder350's Avatar
Auto Parts Professional
Change the VSS (vehicle speed sensor)
thats probly the reason for the check engine light also.
Old 03-28-2008, 08:47 AM
302 Z28's Avatar
We have an 04 Tahoe that the speedo started acting up on. It would slowly fall from 65 to zero and stay that way for as long as the car was running. Eventually the speedo stuck at about 55 mph. Then the Tach started acting up. The Tahoe was still under extended warranty and when I took it in the service writer at the Chevy dealership told me there was a TSB (Technical Service Bulletin) on the instrument cluster. They replaced the entire instrument cluster. I would hate to have to buy one of those things, bet it ain't' cheap. You might be lucky enough to get it fixed if you don't have a huge amount of miles on it.
By the way the speedo is all electronic, no cable involved at all. If the VSS is bad you will see problems in other areas like transmission shift points.
Vince
Old 03-28-2008, 09:02 AM
Holder350's Avatar
thats true Vince, Hadn't thought of that. A good test is the cruse control, if it works then the VSS is good if not then the vss is bad
Old 05-04-2008, 04:20 PM
04 chevy cluster
Chevy had a recall on these if you have less than 75000 miles they will
replace it.
Old 05-06-2008, 11:30 PM
replace it.
Just my luck ... my 04 is over the 75 thousand mile mark
Mine wants to act up when it is under 50 degrees ... over 50 degrees ... no problems.
TH400 Speedo size Derkyb Transmission - Rearend 0 08-21-2007 07:27 PM
SW speedo question 37fordpickup Electrical 2 12-19-2006 10:14 AM
Speedo calibration novatech Transmission - Rearend 2 02-12-2004 08:46 PM
Questions, questions, questions? slider in wa Transmission - Rearend 2 09-27-2003 03:01 PM
Speedo not working..4spd Trav Transmission - Rearend 5 07-31-2003 02:21 AM
