need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-23-2006, 03:41 PM
need help
i have a 307 V8 and the vaccum lines don't seem right it's at high idle all the time and hesitate sometime i was looking for a diagram so i can put the lines where they go
Old 12-09-2006, 11:01 AM
pepi's Avatar
How’s that hopey-changey thing
Last wiki edit: Determining top dead center
Last journal entry: Quicky frame dolly
307 sounds like a ford, suggestion, find another shoot a digital and compare, factory manual, maybe chiltons, vacuum line are like wiring, must be right to work. high idle sounds like a dis with the vacuum advance disconnected
Old 12-11-2006, 04:01 PM
Almost there
i agree with pepe compare and check from the manual also check timing could cause some hesitation
