Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with a 12 v to 6 v reducer
Old 06-17-2006, 09:38 AM
oldguy829's Avatar
oldguy829 oldguy829 is offline
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
12v to 6 v
Doc, I just read my post, and it seems confusing. I used the term sender once, meaning the gauge, not the sending unit in the engine. Might have been confused in your answer also. Your last sentence said "the reverse will apply if the sender is Too high... and make that value resistor, go between the sender line and Ground" ... I read that as gauge and ground. don
