Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help with a 12 v to 6 v reducer
Old 06-24-2006, 12:01 AM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
Doc here,
100 to 30 should be fine..If they don't have that you could go 100 to 0 , just remember it"s high on the "Hot" side a little bit..In fact I'd get a couple around that value if they are cheap enough..you can "Fine tune It " a little bit..
When you get it, boil a pan of water 212 Degrees, and hook the sender up , you need to jump the ground to complete the circuit..get an accurate lab or Kitchen thermometer, and submerse them carefully in the water..
Get a Note pad , and note any variances throughout the range as the temperature declnes..(so you know , for instance the gauge is 6 high through , say , 150 to 165..) and keep the list for future referance..If you have a hot plate..that you can bring to the car..you can do it in both directions.
This will give you an accurate idea of your "Linearity" of the gauge.
Doc
