need help with a 12 v to 6 v reducer - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 07-01-2006, 04:33 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
$50 bucks is a major mark up... You can buy one if you want to go that route..Or build one for under $20 bucks...
You'll need to go to Rat Shack, and get the following, :
  • One 7905 POSITIVE regulator..about $2.95
  • One micro processor heat sink about 3 inches square..($5 to $8 bucks)
  • some heat sink grease, and a 3 tab regulator mylar gasket (under $2.00)
  • a .1 ufd disc cap (2 for 49 cents)
  • a red ring terminal
  • heat shrink tubing for regulator leads
Look on the back of the card the regulator came in, it should read left to right as you look at the front of the regulator, "Input" , "Ground" , "output", ..
You will mount the regulator on your heat-sink material, drill a 4/40 tap hole, and chase the hole with a 4/40 tap..next apply some heat-sink grease, then your mylar gasket, then more grease, then mount the regulator...
Next, solder a red 24 gauge wire to the input side of the regulator, (far left), and leave a pigtail as long as you need to get it to a SWITCHED 12 volt , 1 amp fused source..make this wire RED..
Along with this wire, solder your .1 ufd cap between the ground (center terminal) and this terminal, wrap a few turns of the cap leads to the bottom of the regulator leads and solder, then position the cap and leads so it will "Stand up" parallel to the regulator, make sure the lead on the left terminal does not hit ground.
Next , solder a 24 gauge wire to the center leg of the regulator, , make this wire black, run it as far as you will need to make a good properly bonded ground, burnish paint, grease, dirt, to bare metal, install a star washer and lock , your red ring, and then ground the terminal..
Finally, install a 24 gauge wire to the right terminal, leave enough wire to go to the Gauge power wire,
Lastly, install on each wire, about 2 inch pieces of shrink tube (do this before you hook it up..good thing to tell ya last huh? ) Slide it up the wire to the regulator terminals and shrink them down..be sure that the left and right terminal can not hit the heat sink, or they will short out..If you worry about it, you can install a small piece of electrical tape under the terminals in addition to the tubing..
TO TEST:
Apply 12 volts to your RED wire, And ground to the Black wire Or heatsink..then with your DVOM set for DCV, 12 volt scale, read the orange wire, It should read 5 volts..If you have that, your good to go..install it..
You may note the regulator is running at 5 volts instead of 6..that is because of it's make up, it is a 5 volt regulator..instead of 6..
I say use this one simply because 6 volt regulators are much harder to find at rat shack..and the gauge will never notice the difference..
It is designed to run at + / - 20 % of input voltage..the voltage swing on the old generator system was worse that that under a full load..so you should not have a problem..HOWEVER, ask for a 6 volt regulator first, if you can't get one use the 5 volt regulator..as long as you have 8 volts at the input it will be rock solid 5 volts at the output..(no swings)
The only rule, do not exceed 1 amp on the output..(a gauge system will not exceed this..) But do not "ADD " anything else to it or you'll blow fuses..If you need more, split the loads up between multiple regulators and mount them on the same heat sink.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
  #17 (permalink)
Old 07-03-2006, 05:16 PM
oldguy829's Avatar
Last wiki edit: Swapping to rack and pinion steering
Last journal entry: 53 coupe
Wiki Edits: 88
12v tp 6v gauges
You were right about the mark up Doc. I found one for $20.00. VRC601 Instrument cluster voltage regulator. All chrysler products mid 60's to mid 80's. Wired it in, in place of the voltage reducer, both gas gauge and temp gauge. Turned the switch and got correct gas gauge reading and about 100 on the temp with the sender in cold water. In about 5 seconds both of them quit. Like I pulled the power. Checked all the grounds etc. tried again. lasts about 5 seconds. By then the water was hot, and I was back to square one. The temp gauge will read about right for a second or two, then roll over to the peg, just before the whole thing shuts down. Assume the voltage regulator has something in it that is shutting it off?? Possibly responding to the same thing that is pegging my temp gauge?
I'm clutching at straws here Doc. - my temp gauge does not have a separate ground, it grounds thru the case. Maybe I should dis assemble it and be sure the leads aren't grounding internally somehow. Would that explain both of these phenomenon? (ps, for the one second reading I get before the gremlins take over, I think the sender/gauge is matched somewhat)
  #18 (permalink)
Old 07-03-2006, 07:50 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
I'd Be willing to bet, Somewhere on that 6 volt power line, some ham handed mechanic wired in a 12 volt device...Panel lamp, radio, ect...
The regulator Chip is only good to and amp or two..much over that draw, It will overheat and go into thermal shut down..(off until Cool ...until it finally overheats and goes thermal forever..)
AND that sounds like exactly what you may have...
First Do as you suggested..Carefully pull the covers and be sure you have a good case ground..(It couldn't hurt at all..) and if you feel you need to add a Wired Ground to each instrument..
NEXT Remove the Power wires altogether from the power pick up on the gauges..wire the output of your Instrument regulator to the gauge power Terminals (insure nothing else is on that wire..but the gauges you wire)
NEXT, wire the 12 volt side of your instrument regulator to a known reliable 12 volt switched source.
IF yours requires it, Wire the regulator Ground to a good , proper bonded ground , burnish all paint, grease and dirt down to bare metal, use a star and lock washer.
If that sets it right..you have a 12 volt device on the old 6 volt feed miswired..You will no longer need that circuit , so strip it out all together and you'll probably find a 12 volt item not working..
If I'm correct about what I suspect, this is a very minor malady , of the potential problems running Split busses...
This is why I DO NOT advocate them, and why I always recommend the "All or nothing at all " approach to a single voltage buss..A serious problem could occur, the other way around..a HIGH draw 6 volt item wired into a 12 volt buss..
Check it out and let me know..
Doc
Innovations
  #19 (permalink)
Old 07-04-2006, 09:54 PM
oldguy829's Avatar
Wiki Edits: 88
6v to 12 v help
Well Doc. I did all those tests and came up blank, so I pulled it out and went back to the bench. It is definetly the gauge. Funny it didn't do it the first time I ran the resistance tests, but it is doing it now. Maybe that original voltage reducer didn't reduce enough and messed it up.
fortunately, the car came with a spare in a box of stuff. It's an after market, but pretty close. It has been modified with what looks like some resistors soldered to the field terminals, so of course the values are different, but I can handle that. I'll let you know how I make out in a day or two.
In the meantime, what about the amp gauge? It works, but is not hooked up. I've heard not to use it, and others who have had no trouble. i don't know of an aftermarket volt meter i could substitute into the pod. Got any thoughts on using the original?
If so, Since my system is wired in parallel (I assume that's what it is since my two alternator wires are connected in the middle) can I hook the gauge in one side, or do I have to split them to wire it in in series?
According to AZ, my alternator was putting out 52 amps under the load test. I assume that is the combined output from both sides? Also hope to add A/C soon, so factor that in.
Also, I can find no fusible links in the system. Your diagram shows one on each leg. Should they be closer to the battery, or closer to the alternator? What amp rating would you recommend?
BTW, you mentioned running 2 busses. 12 v and 6 v. Not sure what that means, cause I don't know what a buss is. Everything on the car is 12 v, except the gas and temp gauge.
Doc, is there any way to repay your kindness here?
  #20 (permalink)
Old 07-05-2006, 01:10 AM
docvette's Avatar
Wiki Edits: 12
Originally Posted by oldguy829
Well Doc. I did all those tests and came up blank, so I pulled it out and went back to the bench. It is definitely the gauge. Funny it didn't do it the first time I ran the resistance tests, but it is doing it now. Maybe that original voltage reducer didn't reduce enough and messed it up.
That's pretty rare to find the gauge inaccurate..usually it is operable or not..but good catch..let me know how the new one works out!
I Don't like them, never did..they are dangerous in my opinion..When you have full battery potential , that is hot 24 / 7, 365....at the dash board and wires carrying it through the firewall..that you can drop a tool on, or catch your watch band..and burn holes in the metal..and maybe injure yourself..PLUS on most..If the shunt burns out in the gauge..your powerless..
Some will tell you "I've used them for 30 years, Never had a problem.." It only takes one time...to go tragically wrong...
I don't understand what you say when you say it is wired two in Parallel? Do you have 2 battery's? Two systems or what? If your referring to 12 volt / 6 volt..you are not feeding both separatly..(at least I would hope not..) If so you are overcharging the 6 volt buss..
The Amp gauge will always install between where the battery bolts to the source (like at the starter, ) and the load, the WHOLE car where the fuse buss wire connects at the starter solenoid....Current will go through the meter on to the car ..to be effective..
There should be "No two sides.." THERE SHOULD BE ONLY ONE OUTPUT from the alternator going to the battery terminal at the solenoid...anything else is something different.
Fuse links were not installed at the factory until after 1970..so it's not surprising you didn't find any..With your current system, a 70 amp link should be fine..your alternator is probab a factory 63 amp unit. The fuse links will always install at the battery end of the circuit or at the solenoid...ALWAYS INSTALL THEM IN THE ENGINE BAY NOT INSIDE THE CAR...
A buss is a system of wires that joins together at a common fused point..one main power wire in to a brass bar...and several smaller FUSED outputs coming off that bar..a split system is a 6 volt bar and then a 12 volt bar...separate from each other.
Yes there is...do your wiring safely, and then, enjoy your rod when your done!!
Doc
Innovations
  #21 (permalink)
Old 07-05-2006, 01:42 PM
oldguy829's Avatar
Wiki Edits: 88
12v to 6 v temp sending unit
Here we go again Doc. I just don't know enough to ask an intelligent question.
There are 3 wires coming out of the alternator, as in your diagram. (One off a terminal on the top, the other out of a push in connector along with the brown wire). 2 of them look like 10 ga. power wires (Red). They connect in the middle and it looks like one goes to the battery, via the starter, and the other to the main fuse block. (guessing here cause it goes into a large harness). When I say they are connected in the middle, literally, about 2 feet out of the alternator it looks like the insulation was pulled back and the 2 wires are clampled together with a big staple(?), wrapped in electrical tape, and then both continue on) Guess I misunderstood again. I thought one sent power to recharge the battery and the other to the system based on demand. That's why I was puzzled to see them connected together. (also thought this was an example of parallel wiring - which is still a mystery to me).
So. I will install a 70 amp fusible link in the wire coming off the solenoid. Your diagram showed 2, so I wondered where to put the second, since I don't have the typical horn relay.
Reason I ask which side to put it on, based on my assumptions above - I assumed the lead to the fuse box would not carry as much power as the line to the starter/battery, so it might be safer, but I don't know what the hell I'm talking about. . Yes, I can see how a defunct gauge would shut you down.
I've attached a picture of a gauge. Think I might find a volmeter gauge I could sub in for one this size and shape? Don't know when they went to voltmeters, but from about 55 on they seem to favor round gauges, or idiot lights. I could probably swap out the face plate to make it look OK. I really wanted to avoid some aftermarket gauges hanging off the dash.
thanks again, don
  #22 (permalink)
Old 07-05-2006, 02:34 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
OK, to Clean all that up, Strip out that wire..(except the brown wire..)
Install a fuse link at the Starter solenoid..70 amp. From there run One 10 gauge wire to the big bolt on the alternator..
From the top plug, locate the red wire there, and cut it long enough to reach the big terminal, and cut it and install a ring terminal, Bolt it to the big terminal.
The brown wire will remain the same.
You need only 1 fuse link this way on the alternator.
Next on the wire that brings power to the car..to the fuse buss (panel) , locate that wire (should also be on the solenoid, or single terminal at or near the battery..(It's the wire that when you pull it, the whole car goes dead from power..) Install a 70 amp fuse link there. This will protect the whole system..
That "Wire" that you said was crimped..sounds like the fuse link..but scrap it all and do it as above. It's Cleaner.
As far as that gauge..
Try these guys,
Gauge restorations
Tell them you'd like to convert it to a volt gauge and also will need the gauge re~silk screened to match a volt gauge from amp meter..See if it is cost effective, and what they can do for you.
Doc
Innovations
  #23 (permalink)
Old 07-05-2006, 08:07 PM
oldguy829's Avatar
Wiki Edits: 88
12v to 6v help
OK Doc. Before I rip it's guts out, let me walk through it once. Never used this "quote" response, so bear with me.
Originally Posted by docvette
Doc here,
Starting with Red1 - this wire comes from the big terminal on the alternator and goes to a terminal block on the firewall (along the way it is connected to Red2). Here I unwrapped a lot of black tape and found a fusible link, hand twisted in line no less, and then it goes to the Battery terminal on the starter solenoid. I am to take this out and replace it with a new 10ga wire directly from the alternator to the solenoid, with a new 70 amp fusible link.
Red2 comes out of the alternator at the push in terminal (next to the brown wire) and after connecting with Red1 goes to the buss. I am to cut it off about 6 inches out and jump it over to the same terminal as Red1.
I'm guessing you are talking about Red2, but the end away from the alternator. It connects to the buss on one end, and via it's connection with Red1, effectively goes to the battery terminal on the solenoid. this link would be missing when I pull Red1. You want this to be a direct link from the Buss to the battery terminal on the solenoid, with another 70 amp fusible link. Note; The positive Battery cable has a secondary lead (looks like 10 ga.) that is not connected. Would it be appropriate to run Red2 to this lead (directly to the positive battery terminal) with the fusible link? Seems like this is its ultimate destination, or does it need to be at the solenoid so it is connected to red1?
If I'm wrong about Red2 being the right wire, I'm lost. There is a heavy wire from the buss to the other terminal on the solenoid, but I thought that was coming from the ignition to the starter. Not a power wire like you describe. The only other large wire from the buss dissapears behind the engine and I think hooks up to the distruibutor for the ignition circuit. Again, power out, not in.
If I understand so far, then the brown wire for the alternator must be a feedback wire that tells it how many amps to put out? Where does it originate?
Hope your next message doesn't start with " whoa - Stop" LOL.
Try these guys,
Gauge restorations
I'll give them a try. You apparently don't believe there is a safe way to use an amp gauge.
Doc
I'm going to send another reply, RE the temp gauge. I need to keep these issues separate. don
  #24 (permalink)
Old 07-05-2006, 08:31 PM
oldguy829's Avatar
Wiki Edits: 88
We are making progress here Doc. Picked up another sending unit that was supposed to match my needed values. Wired it all up on the bench and, damn, it worked. Of course, we now get to talk about "linearity" (sp).
After chasing it up and down the range with my little 2 cup coffe maker and a candy thermometer, I narrowed down the problem. Not sure this is Kosher, but what the hell. I wired a 100 ohm resistor into the sender line and got an accurate reading from about 160 degrees to 180 degrees. At about 195 degrees I had to replace it with a 70 ohm resistor to get the right gauge reading, at 210 I had to drop to a 30 ohm resistor. [the specs on the sender were 450 ohms at cold to 30 ohms at 220, so the sender could be performing properly, just not linear with the gauge, is that right? ]
If you are going to tell me what I think you're going to tell me, speak slowly and use small words like you were talking to a child. skip that, todays kids would probably get it before I do. Just remember, the gauge has been modified once already. don
By the way, I had one of those spiritual moments, Just sitting there looking at a temperature gauge that was working.
  #25 (permalink)
Old 07-06-2006, 04:02 AM
docvette's Avatar
Wiki Edits: 12
Doc Here,
OK, on the first post..
To make it simple..just strip the red wire from the solenoid that goes to some "mid~point " splice and tons of tape where the second red ties in..
In other words all that should be left on the alternator is THE BROWN wire and a Stub of the red wire from the top plug, next to the brow wire ...
NOW, run a 70 amp fuse link directly from the starter solenoid battery cable bolt, then attach a RED 10 gauge wire to it, route that to the alternator, at the bolt or + OUTPUT lug at the back..and cut the wire...
Next take your second red, The Regulator switching, route that from the plug to the area of the + bolt or lug on the back of the alternator cut that there....Strip both wires, and Get a YELLOW ring terminal, CRIMP BOTH wires into it, and bolt it on the + lug bolt...
Leave the Brown wire alone , it is the idiot lamp..
You need only one fuse link for this circuit as your running an equiv, circuit, through the same link using one wire.
OK, On the Sender..It is perfectly acceptable to "Pad" a range for linearity, SO long as the upper scale of temp is not off the map..
I.E..It does not go from 180 to peg...
and the errors are only a few degrees + / - actual, otherwise you might as well not run a gauge at all..just get a lamp..it would be as accurate.. (maybe) Point is..If it is way out of the ballpark..except for one "small range".. you run the risk of engine damage..
If it gives a Good range that you can live with , and are aware of the errors at certain points..get that value resistor..in a 1 watt version ( or 2 1/2 watts twisted and soldered together) and solder it in line on the sender wire. 1/2 watt will probably get a little warm..
Doc
Innovations
  #26 (permalink)
Old 07-31-2006, 03:03 PM
oldguy829's Avatar
Wiki Edits: 88
6v to 12 v conversion
Hey Doc, got sidetracked with vacations etc. About the linearity on the temp gauge/sender issue. You recommended 1 watt (or 2 half watt) resistors. I noticed radio shack had some 10 watt resistors that looked nice and stout, with apparently a heat resistant shield, that would apear to be more durable under the hood. What is the effect of using 10 watt, rather than 1 watt, resistors in this application? don
  #27 (permalink)
Old 07-31-2006, 05:15 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
The only thing the WATTAGE of the resistor will effect is it's ability to sink or transfer heat from it to it's surrounding area without burning itself up..you may always go higher on wattage if space is not a problem..
It's the ohmic value you must abide by..
Doc
Innovations
  #28 (permalink)
Old 08-11-2006, 07:14 AM
oldguy829's Avatar
Wiki Edits: 88
6v to 12 v help
Well Doc. With your kind and generous assistance, I would like to continue my education. I am making progress with the temp gauge, here is where I am.
1. On the bench, I have used a variety of Ohms resistors to plot the curve of my temp gauge.
2. Using a pot of water that I can both control and record the temp of the water, I have tracked the ohms resistance present in 3 different sending units through a variety of temperatures from 100 to 212.
(all 3 had the approximate high and low values of my gauge, but varied in the linear curve)
3. (This is where I previously hit the wall ) When I hook up a sender to the gauge and the heat the water, the gauge does not respond properly. For example, at 50 ohms resistance the gauge reads about 130 degrees. But when the water reaches about 145 degrees (where the sending unit has a reading of about 50 ohms) The gauge starts to climb unitl it reads about 190. With the water temp above 145 degrees, it just pegs the gauge.
Last night (out of frustration mostly) I added ohms resistors to the sending unit wire. It worked! With a resistor, any resistor, in the line - the gauge would give me a stable reading that was in line with the bench test guidelines. I finally settled on 7 Ohms as the neccesary resistor for one of the sending units. So my question is... What gives??
Why does the resistor in the line stabilize the feedback from the sender?
Did the original 41 sending unit have something that is missing from modern units to accomplish this?
Now for step 4. To permanently install a 7 ohm resistor in the sender line.
This leads to my next question. I didn't have a 7 ohm resistor, but in experimenting came upon another mystery. When I wire 2 - 10 ohm resistors end to end, it creates 20 ohms of resistance. When I wire 2 of them together side by side, it creates 5 ohms of resistance? When I wired a 10 and a 22 side by side, I got 7 ohms of resistance? Can you explain this? I will be looking for a thermal shielded 7 ohm resistor today, but if I can't find one a 10 and a 20 wired side by side may be close enough. any problem with that scenario?
Thanks again Doc.
  #29 (permalink)
Old 08-11-2006, 02:31 PM
oldguy829's Avatar
Wiki Edits: 88
6v - 12 v help
Doc, can only find 1s 10s 50s in the 10 watt shielded resistors.
I wired 2 10s together (5 ohms resistance) and a 1 tagged on the end (series) and it reads 6 on the meter. It is within 10 degrees of actual and reads a touch high (which is better than low) so I think I am set.
any no-nos before I make this a permanent installation? don
  #30 (permalink)
Old 08-11-2006, 04:15 PM
larryblack's Avatar
Certified Lead Foot
Solder the resistors together and to the wires. Use a wire to the gauge so you can mount the resistors where you have room. They should not get hot but place them where they are not against something that might melt just to be safe.
Get some "SHRINK WRAP" from where you got your resistors. They should know what it is. If not Rad Shack has some or any local electrical parts house.
Shrink wrap is a tube you cut to slide over your resistors. Make sure it covers all exposed wire too. Use a heat gun or hair dryer and heat it. It will "shrink" down in size insulating the exposed wires and connections.
If you solder the wire to the gauge, you can put some shrink wrap over the connection to help keep corrosion from forming. Shrink wrap will present a much cleaner look than tape.
You asked about series and parallel resistors. There is a formula for determining total resistance. In series you just add them like you did and you get total resistance.
In parallel you have more than one current path. This actually reduces the total resistance of the circuit. The formula basically has you multiply the resistor values and divide that value by the sum of the resistor values. Any time you parallel any resistor with the same value you 1/2 it. If you have 3-10 ohm reisitors in parallel you have 10 divided by 3 or 3.33.
All gauges are not linear or move a specific amount with a specific change in what you are measuring. If you look at some temp gauges they change 50* in the first 1/4 arc and then move 50* in the next 3/4 of the arc. This is why there is sssssooooo many senders out there.
I applaude your tenacity to get your factory gauge working. I also see why Doc has such a stellar reputation for helping.
Distributor Tuning and Theory - Part 1 Rick WI Engine 35 04-26-2011 12:38 AM
I need help with ID of a 12 bolt rear end Please ! rr67gto@aol.com Transmission - Rearend 9 03-19-2006 03:36 AM
Want 12 volts ,have 2 6 volt batteries. moodier Electrical 12 10-09-2005 06:35 AM
New 12 bolt rear? strikingthematch Transmission - Rearend 3 07-28-2004 11:41 PM
How to identify Oldsmobile 12 bolt? elukas Transmission - Rearend 8 12-13-2003 10:59 AM
