need help 1951 inline six upgrade - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-04-2011, 05:28 PM
I currently have a 1951 styleline deluxe with a bad 235 splash engine in it. I would like to do a simple and cheap swap does anyone have any thoughts? I currently know where I can get a complete nice running 235 blue flame from a 1956 / 57 belair. Would this bolt right in? What changes would I have to do to install in my 51?
Old 02-04-2011, 05:41 PM
bigdog7373's Avatar
Of course it's fast
Why not rebuild it? It would be relitively cheap and will keep the car "numbers matching".
Old 02-04-2011, 05:52 PM
not a fan of the splash motor. will keep for a later date. a friend of a friend has the blue flame & will trade me for 350 engine dress up kit. looking for the cheap way out at this time.
Old 02-04-2011, 06:08 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Visit the Stovebolt web site;
clik here
Old 02-05-2011, 12:34 AM
Wiki Edits: 31
yea, babbit pounders are expensive to rebuild, assuming you find a machine shop willing to do the machine work, like machine the block for insert bearings or have it re babbited.. the direct bolt in is the '53-'54 235.. even looks original as it used the same 2 bolt center bolt valve cover.. '55-'62 blocks used a water pump that doesn't fit in the smaller '49-'54 chassis and it will need tinkering to make it fit, tho it can and has been done..
Old 02-05-2011, 07:18 AM
Wiki Edits: 27
twice pipes smitty's
nothing sounds as good as twice pipes, glass packs, lowered look and skirts, nozed and decked, takes me back over 50 years ago in high school ! ! ! We ran a truck carb and high lift rockers, new timing gear, it was faster than the fords
Ford inline six to 2300 inline 4 swap. 74chevyflat Engine 3 05-20-2010 10:12 PM
1951 gmc hogghead Introduce Yourself 4 10-19-2009 07:42 PM
i need a 235 for my 1951 buggmann Engine 9 10-22-2007 05:53 PM
dual inline 6's inline 12! 87442lover Hotrodders' Lounge 6 06-17-2004 06:25 PM
1951 chevy inline 6 intake manifolds lgsteelhead Engine 5 01-07-2003 06:26 PM
