need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2011, 04:26 PM
sbcdude's Avatar
need help
i got a sbc 355 i am needing to know what would be a good intake an what size holley carb to run
Old 12-31-2011, 08:04 PM
You have to supply more information about your engine(compression, cam, heads), the chassis its going into, intended use, axle ratio's, and what you expect out of it.
Old 01-01-2012, 09:52 AM
sbcdude's Avatar
more info
I have a1990mustang coupe 355 aluminium afr heads 202/190 doug herbert solid roller cam 11-5-1 forged trw pistons h beamrods 2speed glide wtransbrake 4-88 gear trying to set car up for 1/8 mile just need good intake an holley set up i think the cam is a585 lift dont have specs on me right now
Old 01-01-2012, 10:35 AM
techinspector1's Avatar
Senior Curmudgeon
Wiki Edits: 326
What's the rpm range of the camshaft and what stall range in the converter?
Old 01-01-2012, 12:24 PM
sbcdude's Avatar
need help
The cam range is 3500 to 7500 stall is 4000 to 4500
Old 01-01-2012, 01:09 PM
Senior Curmudgeon
Wiki Edits: 326
Here's a lineup of Edelbrock manifolds for the SBC in your rev range. I'd probably begin with a Victor Jr. and 750 double pumper. Once I established a credible baseline, I might begin experimenting with spacers/turtles.
http://www.edelbrock.com/automotive_...ictor-sb.shtml
I will normally recommend a high-rise, dual-plane manifold such as an RPM if revs are 6500 or less and you're going to use a stall of 3000 or less, but your application will require more manifold, so the Victor Jr. single-plane would be a better fit in my opinion.
