need help
i built a bbc 468 with12;5;1 compression with a soild roller cam with a lift of 714 timing at 32 degrees and total timing at 40.i had chuck nuytten build my 1050 dominator, and i am running a th350 tranny with a 4500 stall, my problem is when there is a load on the motor at around 2000-4000 rpms it breaks down like the msd box is at its rev limiter i changed msd chips , changed plugs , rotor cap and rotor button and even the coil and still no luck. can some one help me im at witts end its driving me crazy
im running 115 octane, i have a msd 6al box with a msd blaster 2 coil and a mallery unilite dist. do you think the dist is junk i never had a problem with it when i had it in a small block i was told b4 they were but it never crossed my mind any suggestion on ignitions to go with. thanks
problem solved
thanks guys for the info, but i think the problem is solved. the rev limiter went bad in the msd 6al box. when i take the rpm chip out it runs fine, when i put it back in the same problem, i tried a hand full of different chips and it did the same thing. so im sending it back to msd to have it fixed. thanks again
