Need help - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-17-2013, 11:52 PM
Need help
howdy im working on a 87 chevy 3/4 ton 4x4, ok now im wanting to know now if i can take a wire harness from a 87 half ton truck automatic and put it in my 87 3/4 ton 4x4 granny four speen, the wire harness has been all cut up on my truck and im parting a half ton out to fix my truck, plzs help me would be a plus, well god bless and be safe yall
Old 03-18-2013, 03:43 AM
EOD Guy's Avatar
Sure, with the right wiring diagrams you can put anything in anything...... You ned to get the wiring diagrams for both the auto and manual 4X4 versions.
Should fit with little trouble, as you remove the harnesses from both trucks, take pictures of each and every connector before you disconnect it, use some blue painters tape to label each and every connector on both sides of the connection. You'll tend to believe you'll remember where that wire went, etc...... you WON'T, don't ask me how I know this....
As far as some areas you'll have to pay attention to.....
Clutch switch in the old harness, won't be in the new....
Auto tranny wires, in the new harness not in the old (just tape them up out of the way)
4X4 wiring etc.........
Old 03-18-2013, 04:30 AM
Banned
the engine side of the harness should be the same if both trucks have v8's and same gauge package (i.e. both idiot light or both gauges)
and if both have the quad head light front end..
the cab harness you'll have to check.. the clutch safety switch could be just a different ign switch and or a completely different harness..
the auto in a 87 isn't computer controlled so that not be a factor but may have electric speedo hook up..
the ecu would be different..
I'd think the bean counters at gm would've speced two different ign switches to deal with the clutch over 2 different cab harnesses..
but then again with or without power windows/locks could've been different harnesses..
I'd post this here The 1947 - Present Chevrolet & GMC Truck Message Board Network - Powered by 67-72chevytrucks.com
in the electrical part of the forum.. as someone will have the g.m. manuals and know for sure.. if and what might be different..
Old 03-18-2013, 10:39 AM
im changing the wire harness in the cab and out, i want mine to be elec window and locks, and im wating to change it cuse the guy had it befor me cut alot of wires cuse my fuel pump runs 24 7 when you turn the key on and not running, and some other weird stuff to
Old 03-18-2013, 02:54 PM
EOD Guy's Avatar
even if the new harness doesn't have elec windows/ locks they are very easy to wire in using a few relays (relays make it easy to work on later IMO)
Old 03-18-2013, 03:01 PM
well the new wire harness has the elec window and locks, my old one dose not, but my worry is 4x4 and non 4x4 and some other odd stuff was diff like my old wire harness has the middle speaker and the new one has it on the sides of the dash, other then that thats what i seen from that
Old 03-18-2013, 07:28 PM
EOD Guy's Avatar
If you label everything as it comes out, you can transplant the need wires, like the 4WD indicator lamp, shift on the fly etc..... to the new harness before you put it in...... it's really not that hard, if you have the diagram and label stuff so when it goes back in it's just a matter of verifing from the diagram and hooking it up.
