need help with 350 - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-30-2002, 03:25 PM
Post need help with 350
i just changed the thermostat in my 70 model 350.
the passenger side bolt had about three washers on it, after i put the thermostat in i couldn't get the passenger side bolt to go back in, the threads are stripped out or something. it just won't tighten up. is there any way to fix this?
Old 10-30-2002, 04:19 PM
Post
You could retap it bigger but I dont recomend it your best bet is go buy a helicoil set and in stall it there not that hard (Wrenchturner)
Old 10-30-2002, 04:23 PM
Post
where can i get the helicoils? how hard is it to put them in?
Old 10-30-2002, 04:40 PM
bullheimer's Avatar
NEVER use credit cards!
Post
did you at least try the bolt without the washers first? (same as using a longer bolt) maybe there's some threads down there the bolt can grab onto
youre never even going to get up to cruising speed at this rate.
[ October 30, 2002: Message edited by: bullheimer ]</p>
Old 10-30-2002, 04:55 PM
Post
yeah i tried without the washers and it didn't seem to help.
Old 10-30-2002, 05:00 PM
Dave E Shank's Avatar
Post
HEY LIGHTSPEED: You can get a helicoil at any good hardware store. Probably independant would be better than chain type. They can show you how to install. GOD LUCK DAVE SHANK
Old 10-30-2002, 06:34 PM
MI2600's Avatar
Member# 3287
Post
Try Peps Boys, Autozone, etc for the helicoils. They're relatively easy to put in.
Old 10-31-2002, 10:12 PM
Post
i bought the helicoils today, is it safe to use them on an aluminum intake, or will the tap build up to much heat?
Old 10-31-2002, 10:33 PM
senor_limpio's Avatar
The Dude
Post
If I'm not mistaken, you can use them in an aluminum intake without problems. Wouldn't be any different than using in a tranny pan bolt situation right?
Old 10-31-2002, 10:37 PM
Post
i have no idea, but a guy i was talking to today said it could build up heat and crack the manifold.
Old 10-31-2002, 10:56 PM
New Member
Post
Lightspeed-
I suggest you fill the hole w/ a light oil and drill the pilot hole slowly and carefully.
Be sure to clean out all the debris after drilling.
Also, I suggest the FIRST thing you do is insert (by hand) a drill bit slightly smaller than the hole until it hits bottom.
Put a piece of masking tape around this bit right at the top of the hole. Now you know how deep to drill.
Measure the distance from the tip (end you inserted in hole) of this drill bit to the tape (measure it Twice).
Then put a piece of tape on the bit you will be using to drill the hole at the SAME distance as you measured.
Now you know when to stop drilling.
Follow the Heli-Coil instructions to the letter.
It ain't hard. Be careful and you should be fine. IF you're all thumbs (and some folks are),
Get a wrench-head buddy to help ya.
Good Luck.
Old 11-01-2002, 03:30 AM
Tazz
Cool
Did you happen to check if there is a bolt broke off on that hole? You may be able to remove the broke off bolt and find good thread to use.
