Need help with 350 Chevy Casting number - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-02-2011, 10:44 AM
I have a 74 Chevy El Camion that I'm redoing, and parts are not matching up for the motor that's in it. I would appreciate help with 2 things.. What does the VIN show that came with the car from the factory 1DS0R4R485484.. And what year is the 350 (casting # 3970010) Numbers on front of the block are 14Z474808 & V07010MR... Any help would be appreciated form this first time board user!
)))---Needlecreek--->
Old 03-02-2011, 04:09 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Vin Number Break Down,
Ok i will break it down for you.
1=chevrolet D=Elcamino custom 80=2-door sedan pickup R=V8 400 cid 2 -bbl
41974 and 85484= production #.
That "S" you have down has to be a "8" there was no letter S for that vehicle.
Cole
Cole
Old 03-02-2011, 04:20 PM
ericnova72's Avatar
More for Less Racer
Any chance that V07010 MR could actually be V0701C MR??, which is 1974 350, 145 hp, auto trans, 2 barrel carb, in an A- body(Chevelle/El Camino). Look close at that stamping, and don't discount the fact that it was stamped by a human being, mistakes do get made and it could really be that the "0" should have been a "C".
"14Z" in the other number also indicates 1974 vehicle installation.
Old 03-02-2011, 05:27 PM
350 numbers? 74 El Camino
Thanks for your help Cole...The "S" must be an "8" The title shows S, but the number on the dash is an 8 that looks a little different than the other 8's on the VIN, (go figure that they had 2 different 8 stamps)....
The O is probably a C as you suggest..I wrote it down as a C as first then took another look and thought it might be a O. Anyway, thanks again for the info...
Old 03-02-2011, 05:42 PM
Thanks for your help...The "S" must be an "8" The title shows S, but the number on the dash is an 8 that looks a little different than the other 8's on the VIN, (go figure that they had 2 different 8 stamps)....
The O is probably a C as suggested..I wrote it down as a C as first then took another look and thought it might be a O. Anyway, thanks again for the info...
)))---Needle--->
Chevy Casting Number Help solidaxel Engine 7 12-27-2010 06:13 PM
Is My Chevy A 350 W/this Casting Number 3970010 CHEVY70 Hotrodding Basics 7 05-16-2010 08:06 AM
Chevy 6 casting number info strummin67 Engine 3 01-02-2010 01:58 PM
Chevy head casting number dr.gonzo Engine 7 04-13-2008 11:29 PM
Chevy Casting Number Mike_82 Engine 0 02-28-2005 10:05 PM
