I don't know if your talking about clearance between the top of the screw head to the back of the cam gear rearward face or the side of the bolt head to the gear hub, and I don't know if if I described that correctly, but either way, you might look at an alternate button head bolt beside the OEM type.
The one I plan to use is stainless and has both a shorter head height and a smaller dia. and seems to clear my Cloyes double roller gear(Set PN 9-3545X9) just fine. The 1/4-20 bolt started out as a 5/8" length but I trimmed it on a grinder to get what I thought was the best length(.550"). Some may advise against stainless as its not as strong as say moly, but I'm going to give it a try. For what its worth. ssmonty |
Cool nice chain set looks almost just like the one I have.Yeah what I was talking about is the top of the bolt head and the back of the cam gear. I only have a little clearance but not much. The bolt head is up a little too high. The side of the head is not a problem its fine. I will maybe try your method. I have a local hardware store that has all kinds of different bolts I will see if I can size something up.If anyone else reads is there a difference between the oem roller cam timing chains and the ones made for the vortec l31 350 block? I thought it was all the same just they changed the bolt distances from side to side on the front of the block.
Thanks Eric |
I think you should contact Summit. they are usually more than happy to help.
If the block is based on the 880 Vortec casting then it will require a cloyes single roller "Vortec" timing set. These are avalible at Northern Auto Parts. If any double roller set is used it`ll make contact with the block and ruin the engine rather quickly. http://www.northernautoparts.com/Pro...tModelId=10001 |
| new block | mikey1476 | Engine | 8 | 04-12-2009 09:34 PM |
| timing chain with a line bored block | 406 ss monte | Engine | 3 | 09-20-2005 05:53 AM |
| pontiac 350 timing issue | Scooby333 | Engine | 5 | 01-14-2005 05:55 PM |
| timing chain? | 85 vette | Engine | 9 | 12-05-2004 06:56 PM |
| late model 6 speed /big block | hemi6spd | Transmission - Rearend | 0 | 12-20-2002 05:31 PM |
