need help with 383 stroker build - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 02-11-2013, 08:41 AM
220cc won't I loose lots of torque I'm looked for obviously more torque the hp
  #17 (permalink)
Old 02-11-2013, 10:35 AM
vinniekq2's Avatar
post 1 you said you were looking for 500/500 and you want to use AFR heads?
There are many combinations and more power available. 1.3 hp per cube is a semi serious street engine,IE;500 hp/383
you also expressed the desire to use a hydraulic roller cam?remember I said to use a moderate solid roller cam.If you go to a hydraulic roller cam to make 500 hp then other items need to be stepped up a little to compensate for the hydraulic cam.
Now if you step up to 550 hp(easily done)that is 1.43hp/cube,you will for sure need the bigger heads(ie;220s)more cam.If you still want to use hydraulic roller then a little more cam still.
Instead of having 500 hp at 63-6400 rpm,you will need 65-6700 rpm,depending on final cam selection.
you have to decide where you like to drive and how you treat your engine.
In my case,my 434 makes peak power at 6500 rpm,first 2 gears I hit the rev limiter when I apply full throttle. Only real problem is dual 3 inch exhaust announces where I just was,,,
  #18 (permalink)
Old 02-11-2013, 10:40 AM
Well I would be useing it mostly on the street but when I step on it i would like to feel that pull of the torque if u guys can put together a good build sheet from top to bottom that would be great
  #19 (permalink)
Old 02-11-2013, 10:56 AM
vinniekq2's Avatar
you need to decide on the heads you will use first.The heads will then get all the parts that match the build.Do you want more torque or torque at a lower RPM? My engine makes a tonne of torque,but the torque peak is around 4700 RPM.The effective rpm range on my engine is 3-6800, idle to 2,000 is fair then things happen in a hurry.The only time my engine is below 2,000 is when Ive stopped..With an automatic the converter choice is important.you need to decide that too.not a bad idea to think about converters/gears/engine RPM range for your application,,,as a package
For comparison,I use TKO 5 speed 3.50 gears,an engine that makes power to 7k.
A good thing about a solid roller,IE,mine,,,it makes peak power at 6500,but continues to make very good power to 6800 with little roll off in power(down about 25 hp @ 6800)
  #20 (permalink)
Old 02-11-2013, 10:59 AM
Well it's a manual trans so prob the torque would be best around the 2000 rpm range and I'm kinda stuck on then afr 195 heads but I am open to suggestions
  #21 (permalink)
Old 02-11-2013, 11:27 AM
vinniekq2's Avatar
my original post,plus 9.4/9.5:1...I would use a callies dragon slayer crank,check weight of crank if you decide differently. Afr 195s with the cnc work. crower rods,wiseco forged pistons.get an sfi approved balancer like fluid.The block needs a good blue print,bored/squared/decked.For a street engine I would probably use 006 PtoW.Cam I would make room for 600 lift,just in case you step up later or move the cam back.You are on your own tuning F.I.,thats dyno time.Would probably want fuel curve at 12.5:1 at W.O.T. for a street car.Ignition curve TBD on dyno.headers should have 1 3/4 primary tubes with consideration for a 1 7/8 step if you plan to rev 6500 often.
The Following User Says Thank You to vinniekq2 For This Useful Post:
1Gary (03-01-2013)
  #22 (permalink)
Old 02-11-2013, 11:28 AM
383 stroker
Vinnie is right. Anyone can throw parts together all willie nilly and hope for the best. The best performing engines are ones that every component works with the others. You want 550 hp but seem decided on the AFR195 heads. Getting to your goal with those heads will be difficult due to their limitations. There are alot of factors that have to be considered when building an engine, such as how its going to be driven. Say we can accomplish your goal of 550 hp...can your clutch and trans handle it? How about the rear end? Anyway, Vinnie told you to decide on your heads, then select a cam to complement those heads,( roller preferably) , then select a carb and intake to match the heads and cam...then headers that will vent that engine. Brother, listen to what Vinnie is telling you...once you decide on certain components, he will walk you through the rest of the build with the best possible parts to match those components...ust dont be afraid to deviate from your original plan. I will be happy to help you as well, seeing Vinnie and I tend to agree on most things when it comes to stroker small block chevy's.
  #23 (permalink)
Old 02-11-2013, 11:32 AM
383 stroker
Although the best kept secret on this site is that Vinnie is running a twin turbo Volkswagon 4 cylinder diesel in his vette.
Nah...just kidding! Vinnie is running a beast of a stroker.
  #24 (permalink)
Old 02-11-2013, 11:50 AM
vinniekq2's Avatar
snakebit,thanks for the kind words. Many members here are very good,and alot of them are better than I am by a fair margin.
Maybe post the link to your truck on you tube to give Marvin an idea what it should sound like.
also,Marvin,why not talk to 1gary,techinspecter,novaSS
Painted jester,and a few more.Im not saying these are the only guys here,there are many many more,snake,bygddy,,now I feel stupid as I have only mentioned a few.
I apologise to the others.,cnc,cobalt,,,arrrrrrrr
fb88,ap,
  #25 (permalink)
Old 02-11-2013, 02:54 PM
vinniekq2's Avatar
cam=256/264@050,street driven,3.50 gears
  #26 (permalink)
Old 02-11-2013, 05:34 PM
painted jester's Avatar
TAKE A KID TO A CAR SHOW
Last journal entry: Wifes 79 comeing together!
fb88,ap,
Vinnie:
You, Fb88, & snake bite got this thread handled, I could only repeat what you guys have already said !! I'll be reading to see what direction Marvin goes?
Jester
  #27 (permalink)
Old 03-01-2013, 05:17 AM
Displacement:383 cu. in.Carburetor:Holley 750 double pumperHeads:Air Flow Research 190cc StreetIntake:Air Flow Research FloPower RPMCamshaft:Comp Cams 280 Magnum hydraulic, with 280 of duration, 230 of duration @ 0.050 in. lift, and 0.480 in. liftHeaders:1 3/4 in.Distributor:MSDTiming:34Comp. Ratio:9.5:1MAX HP:471 @ 5500MAX Torque:515 @ 4500
[COLOR=#ff0000]Combo 16.[/COLOR] Combo 16 uses the same parts as Combo 15, but with a hydraulic roller camshaft. The awesome 500 HP/ 500 ft-lb mark is almost reached. This is an awesome street engine also.
Displacement:383 cu. in.Carburetor:Holley 750 double pumperHeads:Air Flow Research 190cc StreetIntake:Air Flow Research FloPower RPMCamshaft:Comp Cams hydraulic roller, with 230/236 of duration @ 0.050 in. lift, and 0.510/0.520 in. liftHeaders:1 3/4 in.Distributor:MSDTiming:36Comp. Ratio:9.5:1MAX HP:491 @ 5500MAX Torque:501 @ 4000
  #28 (permalink)
Old 03-01-2013, 05:20 AM
i found these builds what do you guys think ? the airwolf heads are to expensive i can get the afr heads for under 1500 i also would be running 10:7:1 compression and multiport fuel injections and 195cc street heads with one of these combos do you think id be over the hp and torque ratings they gave ?
  #29 (permalink)
Old 03-01-2013, 11:27 AM
Banned
IT DEPENDS
There are many 220cc heads that can make more torque off idle than some 180cc heads- volume doesn't mean as much as you think. Its all part of a package.
If you're going to buy an aftermarket head I wouldn't bother looking at anything smaller than a 195cc port, and a 220ish port would be around the max I would look at for a 350 that sees regular street use. Looking at a 245cc port is when it starts to just get silly.
The Assault Racing head (chinese) is a damn good head for the money (its super cheap) and can make over 500hp at a very streetable RPM.
  #30 (permalink)
Old 03-01-2013, 11:37 AM
It's. 383 stroker and I was going to run 195cc heads afr heads
383 stroker build Q's greenmoonshine Engine 20 07-31-2010 04:19 AM
Stroker 383 Build Help shakeyraystingray Hotrodding Basics 13 02-15-2009 10:45 AM
i need ur help to build a 383 stroker hoss15401 Introduce Yourself 2 10-14-2007 06:30 AM
How to build a 383 stroker JAKE 68 GMC Engine 15 05-30-2006 01:28 PM
build a 383 stroker jo5hi3 Engine 4 11-20-2003 12:07 AM
