need help with 383 stroker build - Page 3 - Hot Rod Forum : Hotrodders Bulletin Board
  #31 (permalink)
Old 03-01-2013, 11:37 AM
It's. 383 stroker and I was going to run 195cc heads afr heads
  #32 (permalink)
Old 03-01-2013, 11:53 AM
vinniekq2's Avatar
what heads did you decide? 210 AFRs will get you to 550 HP and the ability to rev 7k?
195 AFRs will get you close with 6600 rpm ish power
if using a solid roller
if using a hydraulic roller consider 6500 ish as a built in redline
  #33 (permalink)
Old 03-01-2013, 12:20 PM
210 heads 10:7:1 compression haven't decided o a good cam yet any suggestions that works good with multiport injection if so what's the part numbers and make ?
  #34 (permalink)
Old 03-01-2013, 12:32 PM
vinniekq2's Avatar
210 AFRs or someone elses heads?
if from another maker,quote flow numbers?
10.7 will require you to tune carefully,FI is a good choice and if you can do it? rpm range you want?
solid roller or hydraulic?
rocker arms or shafts?
  #35 (permalink)
Old 03-01-2013, 01:11 PM
How fast is fast enough?
Good points- I'll add instead of flow number quote the actaul head, provide a link if you can. Flow numbers are also PART of the package and don't mean everything- the large port Vortec Bowtie is a good example of that- it makes more power than the flow numbers would indicate.
  #36 (permalink)
Old 03-02-2013, 04:51 PM
AFR SBC 210cc Chevy CNC-Ported Aluminum Cylinder Heads | eBay
thats with a 65cc chamber that will give me 10:7:1 compression if i go with a 75cc it should drop it down around 10:1 im still iffy if i wanna run such high compression im just takeing off right now im goign to do some reasearch and post a build up on here later and see what you guys think and would change thanks for your guys input
  #37 (permalink)
Old 03-02-2013, 07:50 PM
vinniekq2's Avatar
what about with 68 cc or 70 cc or 72 cc?
  #38 (permalink)
Old 03-03-2013, 02:15 AM
1Gary's Avatar
Last journal entry: Ole Yellar build-1989 383 SBC Astro build
Cam wise for tuning it is better to have a 112 or 114 lobe center.Sure makes tuning easier.
  #39 (permalink)
Old 03-03-2013, 03:46 AM
all i seen was a 65cc and 75 cc chamber in afr ill check more into it been busy
  #40 (permalink)
Old 03-03-2013, 09:25 AM
LUNATI 350-400 SB CHEVY VOODOO 273 SOLID ROLLER CAM KIT | eBay
383 STROKER COMPLETE SHORT BLOCK KIT FULLY MACHINED SCAT CRANK FORGED PISTONS | eBay
i bought this block already do you think the cam would be good for fuel injection and the afr heads i know th lsa is 110 let me kno what u guys think
  #41 (permalink)
Old 03-03-2013, 09:53 AM
so my next question is cause this block with a 65cc head runs 10.9:1 compression withthe flat top pistons if i go to a 75cc chamber head will i be around the 10.4:1 ratio with a standard thickness head gasket ?
383 stroker build Q's greenmoonshine Engine 20 07-31-2010 04:19 AM
Stroker 383 Build Help shakeyraystingray Hotrodding Basics 15 02-15-2009 10:45 AM
i need ur help to build a 383 stroker hoss15401 Introduce Yourself 2 10-14-2007 06:30 AM
How to build a 383 stroker JAKE 68 GMC Engine 15 05-30-2006 01:28 PM
build a 383 stroker jo5hi3 Engine 4 11-20-2003 12:07 AM
