Need help 68 Firebird - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-17-2010, 03:49 PM
68F_Bomb's Avatar
Hello I have a 68 Pontiac Firebird i need power steering pump, brackets, box, heater core (whole assembly).
I am looking at a 72 Buick Skylark and a 72 Oldsmobile Cutlass which would be my best bet for a donor car?
Old 11-17-2010, 06:08 PM
ericnova72's Avatar
More for Less Racer
Nerther of those cars are going to be good places to look. Power steering pump will work but need different brackets, steering box will work but need a '67-69 Camaro/Firebird or '68-74 Nova/Omega/Ventura/Apollo pitman arm swapped on to it. Manual box pitman and power box pitman are not interchangable, different size shaft and spline on output shaft of these boxes. Heater box inner and outer will fit but may not match under dash ducting.
Direct fit stuff will come from the above mentioned F-body or X-body cars, pump brackets will have to come off of something with a Pontiac V8 if your Firebird has a Pontiac motor.
68 firebird into a 68 camaro? pi71 Hotrodders' Lounge 14 11-30-2009 07:24 AM
68 Firebird Camaro rear seat JBKuter Interior 2 05-25-2009 08:47 PM
68 firebird to camaro rear seat 68birdman Interior 24 11-23-2007 11:07 PM
'68 firebird spring perch distance firebirdmi Transmission - Rearend 0 02-07-2004 04:05 PM
Custom 68 Firebird 054teamdaddy Interior 1 01-26-2002 10:03 PM
