Need Help with 700r4 No 4th Gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-29-2006, 02:03 AM
Hi Guys,
I have installed a 700r4 in a 63 Impala that I have built. When I put it in it was supposed to have been rebuilt. When I drove it reverse would shudder and I had no 4th gear or lockup. I pulled the tranny out and found that the pump had some bad wear on it. I decided to go ahead and replace the pump and go through the complete tranny. I replaced averything in it, installed the 9 disc 3-4 plates. Installed a Fairbanks reprogramming kit and every trick that I could find to improve the life of this 700. I got it back in the car and had a great reverse, shifted from 1-2 nice and hard, and also 2-3 but I still did not have 4th. I do get a lockup now so I know that I am getting pressure to the 4th gear valve, but I dont get 4th gear. I really feel that it is in the 4th gear servo but I cannot figure out what to do about it. I have installed a corvette 2nd gear servo and a billet 4th gear servo and cover from Bowtie Overdrives. I don't think that the piston is able to push the pin far enough on the band. The band has been replaced with a new wide band and like I said above 2nd gear works great. Can anyone please help me with this one????
I'm sorry it was so long I just wanted to be sure I had everything that you might ask included.
Before you aks the T.V. cable has been checked, rechecked and checked again with no difference.
Old 09-29-2006, 09:06 PM
Crosley's Avatar
Global Moderator
Wiki Edits: 1659
Originally Posted by Jackson63
Hi Guys,
if the servo is properly setup the apply pin will not reach the band for OD....... I'd recheck the setup ( perhaps you already did ).
the 2-4 servo is a multistage unit. Not setup correctly and it will not function right.
how far in can you push the servo cover ? about .125 is a good place to start.
Old 09-30-2006, 08:26 PM
I have the same problem with a 700R4 in a Suburban. I've been told to check fluid pressures in each gear. I tried replacing the servos with originals also didn't have fourth( I'm using Superior 2-4 Super Servos) I may have more travel in the servo cover than 1/8". I didn't drive the vehicle before I pulled the trans, it may not have had fourth after the last rebuild. Owner said it only gone 12,000 miles on rebuild and then sat for a year. Also it had no external oil cooler, does now.
Old 09-30-2006, 08:59 PM
airworld2's Avatar
700 no 4th
with what you have replaced so far, I would replace the entire valve body it is not uncommon to have a no 4th condition.unless you find a cut sealing ring on the 4th servo piston .the valve body would be my next step, if the pin was too short 2nd would slide 2-3 would be unaffected and 4th would apply .lock up is feed from 2nd gear oil but can be made to apply at different times. 2nd 3rd and after 4th gear shift is made.
airworld2
Old 09-30-2006, 09:49 PM
It is around 1/8" or less. i have even tried installing a washer in the pin beteween the "E" clip and the 4th servo piston with no luck. Today I changed the piston to a new Sunnax dual piston OD servo and it did not make difference. Is there a port that I can pressurize to test the 4th gear piston and see if it is applyind the band? I checked the drain hole but it applys pressure to the 2nd gear only.
Airworld is there any particular thing in the valve body that could be causing this before I replace the body itself? I have checked all of the valves to be sure there is not one stiching and could not find any problems.
Another question that might or might not have anything to do with this is when I took the tranny apart there was a checkball and cup in the housing under the aux valve body. None of the paperwork that I have or have found references this ball just the one in the aux body itself. i did leave it out could this be my problem? What does the aux body do and do I need to install this checkball?
Thanks again for any help
Old 10-01-2006, 01:03 PM
airworld2's Avatar
the ball under the aux valve body slows the apply oil in reverse, for smooth apply gm would call this a garage shift. the aux valve body is also part of garage shift for forward apply and contains a valve called reverse abuse valve this valve will not permit instant reverse engagement when you attempt to rock the truck out of a stuck spot(mud, snow) it will again slow reverse apply. the forward drum has been orifice larger for forward apply and reverse drum has been changed with an air bleed system and larger orifice in stator shaft.
airworld2
Old 10-09-2006, 10:35 PM
Hi guys,
I Still need help with this problem. Here is a liitle more info that might help. I took the valve body back apart to check and be sure that the 3-4 relay valve was installed correctly and everything looked fine. I double checked all of the valve to be sure they move freely and once again everything looks good. I did find the 4th clutch apply port in the case and pressurized it with air to be sure that the band was applying correctly and it looks good. I put it all back together and installed a pressure gauge in the 3rd accumulator and the 4th clutch apply port next to the servo. I ran the car wth the wheels off the ground through all of the gears and watched the gauges. when it hits 3rd gear I get pressure in the 3rd gear port and then it releases but I never got any pressure on the gauge in the 4th gear port. I do get a 4th gear lock-up on the converter but for some reason I am not getting any pressure to the 4th gear servo. If anyone has anything that I can check please let me know, I feel like I have checked everything that I can think of but I know that there is just some little small something that I have overlooked that is causing me to pull out what little bit of hair that I have left. Please help me I'm stumped!
Old 04-20-2015, 10:45 PM
Great thread! I wonder what happened. If Jackson is still kicking 9 years later, let us know.
700R4 2nd gear start/4th gear bind up? myclone1 Transmission - Rearend 3 04-19-2005 03:51 PM
big power loss at 4 g's only in 3rd gear (700r4) mason71 Transmission - Rearend 4 03-26-2005 11:32 AM
Towing in 3rd with a 4th gear lock up kit in 700r4 wed68 Transmission - Rearend 4 03-25-2005 01:34 PM
700 R4 4th gear problem. JOHND. Transmission - Rearend 0 02-04-2004 02:04 PM
700r4 Skipping 2nd gear ThrottleBottle Transmission - Rearend 4 08-07-2003 04:52 PM
