need help about finding out about my engine and heads - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-13-2011, 07:49 PM
back of engine is 3970010
and on front is v0321tka
t8a510763
the heads is 10110810
jo84
i would like to find out all i can about them and if thay will work together
Old 01-13-2011, 07:51 PM
matts37chev's Avatar
I don't understand?
Last journal entry: this is only a test
check some of this Mortec Casting Numbers
Old 01-13-2011, 09:47 PM
DoubleVision's Avatar
TKA 76 350 Truck 165 LS-9 4-Brl
TKA 78 350 Truck 165 LS-9 4-Brl
TKA 80 350 Truck 165 LS-9 4-Brl
TKA 92 350 Truck 210 L-05 TBI
10110810...91-up...350..........Gen. 1, 65cc chambers
The heads sound like swirl port heads, the worst flowing heads in small block history. So going by that, if the heads are original to the block, you have a 92 TBI truck engine.
Old 01-14-2011, 07:57 AM
thank you
and no the heads are not the ones that came with the block am having to pice everything together and havine a hard time getting the engine to run right
Need help finding out what engine do i have? ch4rli3_hxc Hotrodding Basics 1 06-24-2010 01:36 AM
Help finding the right heads for my 383 stroker pittbull7934 Engine 33 07-07-2009 11:11 PM
finding true tdc with heads on kamarofreek Hotrodding Basics 1 04-07-2009 02:24 PM
finding info on engine bigmilk2003 Engine 1 01-21-2008 08:00 AM
help finding right heads stfinney Engine 14 02-07-2004 04:27 PM
