need help accelerating.... - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-28-2009, 02:39 AM
cutthroatkid's Avatar
two cups of tea
Last wiki edit: Need more horsepower for my 305 Last photo:
Wiki Edits: 2
Ok so I (as most of you know seeings I post so much)have an 83 monte carlo with a small block its pretty fast,dished&forged pistons,heads,cam,headers,duals a lot more in the engine etc etc.BUT! Its kind of sluggish out the door I mean once I get to rolling I'm flying its just getting there.Whatshould I do?a shift kit?change the gears?put on a electric water pump&fan?idk,its not a posi by the way/the engine is a low compression 8.5 to 1 it was for the blower but we took the blower off it was 435 hp before so about 350 now,my grandas friend just told me lastnite that were gonna build another engine for it later on&I didn't want to ask him about this issue because,this engine is not his favorite thing(long story)well thanx guys
Old 08-28-2009, 03:04 AM
ericnova72's Avatar
More for Less Racer
REAR GEARS!! All the other stuff added together won't do 1/4 of what a gear change will do. Put 4.10-4.56's in it and you will get your get up and go.
Old 08-28-2009, 04:41 AM
GMCTRUCKS's Avatar
Gears and posi for sure maybe some long tube headers with a free flowing muffler also check your dizzy make sure it not binding also do you have the right carb for your set up sometimes people just put together a engine but they don't get all the right parts like for your heads and so on. Now im not saying you did that but it's just my two cents and I hope it helps you out.
Good luck! RJ
Old 08-28-2009, 08:55 AM
Stinger 99
You didn't mention the txmsn and especially the Torque Converter. The correct torque converter/stall speed will do wonders in getting you off the line. After that I'd take a good look at rear end ratio and tire size.
Flat spot when accelerating Jouba General Rodding Tech 4 02-18-2009 04:44 PM
Engine stumbles while accelerating fastrehotrods Engine 3 06-29-2006 11:34 PM
Won't shift into third while accelerating stinky jinx Transmission - Rearend 2 06-16-2005 05:41 PM
Wondering about accelerating RPM's with High stall torque converter 87Camaro Transmission - Rearend 3 07-28-2004 03:02 PM
Rear end Noise While Accelerating Auto-Part Transmission - Rearend 9 11-10-2003 10:36 AM
