Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help adjusting carb, idles high in part and too low in gear
Old 04-24-2013, 01:12 PM
Brandon H.'s Avatar
Brandon H. Brandon H. is offline
I need help adjusting the edelbrock carb on my s10,it idles kinda high, around 1300-1400, and when in gear can drop low, to the point of stalling some times. I do not know anything about adjusting Edelbrock carbs other then the idle metering. And I haven't even checked the timing yet. I already have advice from another member on the timing, and will check it Saturday..
Where should I start? It runs strong, its just a high idle and gets too low once in gear. I couldn't find any vacuum leaks.
A little info on the 350 below
