Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help adjusting carb, idles high in part and too low in gear
Old 04-24-2013, 01:15 PM
Brandon H.'s Avatar
Brandon H. Brandon H. is offline
It's got a 355 with flat tops, mild worked 882 heads, solid flat tappet cam (cam card below), victor jr 4+4, edelbrock 750, long tube headers, 3800 stall, stock TH350, 10 bolt rear with 3.73 and Lincoln locker. 28.5/10.5 slicks.
(yes I know this motor needs heads and a lot more compression)
Was told it has to be tuned different if the motor has a lot of duration.
