Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help adjusting carb, idles high in part and too low in gear
Old 04-24-2013, 12:20 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Lock out the distributor mechanical advance curve. Set the now fixed locked out timing to 36deg BTDC.
Now reset the carb. It will idle around 1000 rpm. use a 3" or 4" rated power step up spring in the carb.
This cam need a full 36deg locked idle timing to idle correctly with a auto trans.
Get some 4.56's
Hint: instead of trying to "Hot lash" the valve lash set it cold at .022" instead of .026" hot.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
Brandon H. (04-25-2013)
