Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help adjusting carb, idles high in part and too low in gear
Old 04-24-2013, 08:36 PM
F-BIRD'88's Avatar
F-BIRD'88 F-BIRD'88 is offline
Yada Yada Yada
Big cam ='s low manifold vacuum at idle. You want the primary metering rods to stay down lean at idle.
Therefore a low 3" 4" power step spring. Similar to holley power valve selection.
The distributor will need to be locked out with either carb. The edelbrock carb will work fine once the distributor is corrected.
This is the nature of these big racy cams.
edelbrock carb tuning
Volvord 784VC Edelbrock Carburetor
Don't bother with a vac sec carb.
The Following User Says Thank You to F-BIRD'88 For This Useful Post:
Brandon H. (04-25-2013)
