Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Need help adjusting carb, idles high in part and too low in gear
Old 04-25-2013, 11:56 AM
Brandon H.'s Avatar
Brandon H. Brandon H. is offline
I was told if I lock out the distributor I will have to run a toggle switch in between the power wire on the coil, and when I start it I turn the motor over then flip the switch to apply power to the coil or it will kick back.
I use to race Dirtbikes I know how bad kickback hurts. I keeping and eye out for heads, a new rear end hearer lower and a carb, might be a few months though.
Would this switch be needed? I love the cam in this truck, it's well worth the extra hassle.
