Need help adjusting carb, idles high in part and too low in gear - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-24-2013, 01:12 PM
Brandon H.'s Avatar
I need help adjusting the edelbrock carb on my s10,it idles kinda high, around 1300-1400, and when in gear can drop low, to the point of stalling some times. I do not know anything about adjusting Edelbrock carbs other then the idle metering. And I haven't even checked the timing yet. I already have advice from another member on the timing, and will check it Saturday..
Where should I start? It runs strong, its just a high idle and gets too low once in gear. I couldn't find any vacuum leaks.
A little info on the 350 below
Old 04-24-2013, 01:15 PM
Brandon H.'s Avatar
It's got a 355 with flat tops, mild worked 882 heads, solid flat tappet cam (cam card below), victor jr 4+4, edelbrock 750, long tube headers, 3800 stall, stock TH350, 10 bolt rear with 3.73 and Lincoln locker. 28.5/10.5 slicks.
(yes I know this motor needs heads and a lot more compression)
Was told it has to be tuned different if the motor has a lot of duration.
Old 04-24-2013, 05:57 PM
Brandon H.'s Avatar
Sounds good, I will check that Saturday as well. Thank you for the help, that way I know what I'm after when I work on it Saturday.
I am a little confused on the power setup spring though.
I'm going to keep an look out for a Holley. looking at a 750 vac sec, but if I find a good deal on a double pumper would that work too? It won't be on the street except to go to the gas station
Old 04-25-2013, 12:56 PM
Brandon H.'s Avatar
I was told if I lock out the distributor I will have to run a toggle switch in between the power wire on the coil, and when I start it I turn the motor over then flip the switch to apply power to the coil or it will kick back.
I use to race Dirtbikes I know how bad kickback hurts. I keeping and eye out for heads, a new rear end hearer lower and a carb, might be a few months though.
Would this switch be needed? I love the cam in this truck, it's well worth the extra hassle.
Old 04-25-2013, 05:09 PM
33Willys77's Avatar
With that much duration, you may not have any kickback. Try it first and see what happens.
Old 04-25-2013, 07:45 PM
Brandon H.'s Avatar
It doesn't have the brace, I will order one online (hopefully flea bay)
can I unhook the vaccum advanced or do I need an adapter to hold the bar inside the dristributor in a certain spot?
They don't make plates to lock the distributor on a hie do they? I can't find one. Can I take a thick feeler gauge, mark it, drill it, and use the original e clips to hold it on.
I'm researching this as much as I can, even ran into this :-)
Thanks for the help answering my noobie questions
Old 04-25-2013, 09:56 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
Crane Cams #99600-1 Adjustable Vacuum Advance Kit is what I think you need.
I have one here, and the limiter plate is included in the kit as per the above picture. It looks like Summit also sells JUST the limiter plate ... #99619-1
Old 04-26-2013, 02:51 PM
Brandon H.'s Avatar
I made a plate to lock it.
Can I just unplug the vaccum line for the advance or do I need to replace it with something.
my car idles high 82_CUTTINGEVERYTHIN Hotrodding Basics 7 03-27-2013 08:18 PM
stumbling in high gear, low RPM , sounds like metal and rocks Ocean-Angler Engine 18 06-25-2012 02:28 PM
Centrifugal supercharged 5.9 dakota makes low boost in high gear? ForceFed86 Engine 2 06-30-2009 11:08 PM
Idles high Toddclary Engine 24 04-22-2008 01:06 AM
85' corvette idles high WakBordr7387 Engine 6 12-30-2005 01:33 PM
