Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - need help adjusting valves
Old 09-23-2005, 07:58 AM
67bird 67bird is offline
hey guys, i have been going crazy tring to adjust the valves on my engine, well i guess for the first reason being that i was trin to set them as hydraulic. but now i realize they are solid. can someone please help me out, how do i adjust solid cams?!? here is all the info about the engine. thanks alot
engine: 1970 4 bolt, high nickle, nodular iron main caps, bored .30 over, flat top hypereutectic pistons, 215 cc dart iron eagle heads w/stainless 2.05/1.60 valves, comp solid lifter cam (Duration at .050: 260 Intake Valve Lift: 0.555 Exhaust Valve Lift: 0.555 Lobe Seperation: 110) comp alum. roller rockers (1.5),
