-   -   need help adjusting valves (http://www.hotrodders.com/forum/need-help-adjusting-valves-70709.html)
67bird 09-23-2005 07:58 AM
hey guys, i have been going crazy tring to adjust the valves on my engine, well i guess for the first reason being that i was trin to set them as hydraulic. but now i realize they are solid. can someone please help me out, how do i adjust solid cams?!? here is all the info about the engine. thanks alot
engine: 1970 4 bolt, high nickle, nodular iron main caps, bored .30 over, flat top hypereutectic pistons, 215 cc dart iron eagle heads w/stainless 2.05/1.60 valves, comp solid lifter cam (Duration at .050: 260 Intake Valve Lift: 0.555 Exhaust Valve Lift: 0.555 Lobe Seperation: 110°) comp alum. roller rockers (1.5),
johnsongrass1 09-23-2005 08:07 AM
Comp cams has good instructions on the web site. Why are you running a cam that big with low comp pistons? and not 1.6 or .7 rockers?
67bird 09-23-2005 08:17 AM
this is how i bought the car... i did not build it and this is all the info that i have on it. so check out their website? thanks alot anything else?
67bird 09-23-2005 10:26 AM
nevermind i got it done. i did research and it seemed like most of the valve lash was set at .022, so thats where i set'em and wow she runs like she's supposed to again! lol. i totally forgot how great of a motor she was
Henry Highrise 09-23-2005 10:37 AM
The information on how to set valves with solid lifters is in the Knowlege Base on this site. The knowlede Base has lots of good info and even has a search mode, take a look....its fantastic! :thumbup:
67bird 09-23-2005 10:49 AM
man this is the first time i have been on this site in forever, haha i totally forgot about that. it for real has been a long time. thanks alot though i really appreciate it
