need help adjusting valves - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-23-2005, 07:58 AM
hey guys, i have been going crazy tring to adjust the valves on my engine, well i guess for the first reason being that i was trin to set them as hydraulic. but now i realize they are solid. can someone please help me out, how do i adjust solid cams?!? here is all the info about the engine. thanks alot
engine: 1970 4 bolt, high nickle, nodular iron main caps, bored .30 over, flat top hypereutectic pistons, 215 cc dart iron eagle heads w/stainless 2.05/1.60 valves, comp solid lifter cam (Duration at .050: 260 Intake Valve Lift: 0.555 Exhaust Valve Lift: 0.555 Lobe Seperation: 110) comp alum. roller rockers (1.5),
Old 09-23-2005, 08:07 AM
johnsongrass1's Avatar
Race it, Don't rice it!
Comp cams has good instructions on the web site. Why are you running a cam that big with low comp pistons? and not 1.6 or .7 rockers?
Old 09-23-2005, 08:17 AM
this is how i bought the car... i did not build it and this is all the info that i have on it. so check out their website? thanks alot anything else?
Old 09-23-2005, 10:26 AM
nevermind i got it done. i did research and it seemed like most of the valve lash was set at .022, so thats where i set'em and wow she runs like she's supposed to again! lol. i totally forgot how great of a motor she was
Old 09-23-2005, 10:37 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
The information on how to set valves with solid lifters is in the Knowlege Base on this site. The knowlede Base has lots of good info and even has a search mode, take a look....its fantastic!
Old 09-23-2005, 10:49 AM
man this is the first time i have been on this site in forever, haha i totally forgot about that. it for real has been a long time. thanks alot though i really appreciate it
Adjusting valves on SBC after cam install tnman Engine 15 11-16-2010 12:13 AM
Adjusting Valves and Oil mess(or not in this case) jakeslim Engine 6 08-31-2005 11:28 PM
Adjusting Valves EBlack36 Engine 4 08-06-2004 10:16 PM
problem finding zero play when adjusting valves jacobm99 Engine 7 02-24-2004 10:36 AM
Adjusting valves with Roller tip rockers...... joakes Engine 6 10-19-2002 05:54 PM
