need help/advice - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-10-2008, 08:37 PM
56ford's Avatar
need help/advice
hey, i have a 1962 ford galaxie 500 and it has a bad suspension and everything associated with it. what exactly is involved in changing the rear leafs and the front suspension to an air ride suspension that can be used with power discs? is this a job i can tackle on my own in my garage or is it something that should be handled by a pro? any advice is appreciated. thanks.
Old 01-13-2008, 10:24 AM
try this source
I'm running a 64 fairlane -very trick custom. i found the forums on fairlane club of america very helpfull. lots of "how to" articles
good luck1
Old 01-13-2008, 01:22 PM
aka Duke of URL
R U really sure you want to do that to a 62 GALAXIE?
Old 01-13-2008, 01:52 PM
Lrpasco
I get asked about 10 times a day at work "can i install these parts my self?"
My answer is "it depends on how much you have done before, if you have the tools to do it, and mostly IS IT GOING TO BE SAFE. When i was 16 in shop class getting ready to paint my truck i was about 6 hours from painting it when it rolled back and bent the driver door into the front fender. My teacher just laughed and said "metal is only metal, it can all be fixed". So saying that if you screw up o well. do it again. If you screw that up, do it again. It wont take long to know what is right and what is wrong. Now if you were working on a numbers matching restoration, then i would say hold off until you do another car but if it is going to be a custom car, have fun.
Now this is just my opinion and others may thing i am wrong but everyone is entitled to their own opinion.
Old 01-18-2008, 02:42 PM
56ford's Avatar
thanks for all you guys' help. i appreciate it :-)
Need HELP/ADVICE with Seat Belts!!! texastomeh Interior 0 06-25-2007 08:45 AM
700R4 help/advice Mustangsaly Transmission - Rearend 7 12-12-2005 04:54 PM
Blower Help/Advice Classix_Lover Engine 24 10-23-2005 09:52 PM
locker rear help/advice needed Rob Keller Transmission - Rearend 12 08-02-2005 03:32 PM
350 Rebuild 84camaro350 Engine 7 03-15-2004 07:59 AM
