Need Help/Advice re In-Tank Fuel Pump!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-07-2012, 02:03 PM
texastomeh's Avatar
Am installing a POWERJECTION III TBI system on my '63 T'Bird 390 (.030" overbore, MLF-4 Cam, FPA Headers). STRICTLY A CRUISER.
Which of the following (if either) IN-TANK electric fuel pump would you guys recommend (hopefully based on actual first-hand knowledge/experience)?
1.http://www.ebay.com/itm/140685402884
2.http://www.ebay.com/itm/REAL-Walbro-...b4b048&vxp=mtr
3.http://www.ebay.com/itm/255LPH-High-...item4aa6c7b5e4
4.http://www.ebay.com/itm/EFI-ENGINE-I...7bfb11&vxp=mtr
I am installing in a NEW tank, fuel line, return line, etc. so have some flexibility re installation.
THANX in advance for your advice and help!!
Tom
Old 04-07-2012, 07:18 PM
richard stewart 3rd's Avatar
Last journal entry: 351W rebuild
Hi
I'm not a big fan of in-tank pumps, only because of the extra time & work if up-grading or replacing. So when the pump went south on my truck I used a Holley in-line and completely removed the in-tank pump & replaced it with a pick-up tube & installed the sock on the end of it. The pump is attached to the frame below the tank in order to create a siphon. I also fabricated some sheet metal around the pump to protect it from being hit by flying road debris. Now if I were to need a new pump or more pressure for whatever reason, I don't have to remove the tank.
Rich
Old 04-08-2012, 07:46 AM
In tank for me.Iím using an Aeromotive A 1000. Watched my bud go through 2 of the Eliminator Series ($$) before he put his in the tank.Heat was the only thing we can contribute it to. No problems since.Just make sure the pump is mounted lower than the tank.If not,it may cause stall issues.
Ford Fuel Pump Pressures--In tank pump Bryan59EC Engine 9 06-28-2011 02:56 AM
Fuel tank mod advice garretthes General Rodding Tech 4 04-16-2011 09:08 PM
Seeking Advice: Installing Fuel Pump & Fuel Lines horvath Engine 40 04-15-2011 10:12 AM
Use in tank fuel pump or no? BillyJoe General Rodding Tech 7 05-15-2007 08:39 AM
Inline fuel pump vs. in tank fuel pump wheel-7 Engine 2 09-02-2006 06:57 AM
