need help with air compressor - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2006, 04:24 PM
stingingdragon's Avatar
I have a PAASCHE D500 air compressor that i have owned for some time now. I use it for airbrushing, but with problems of not constant air pressure. I have read several times this is because of no tank with compressor, sooo my question is can i get a tank to attach to compressor? if so, where can i get one? how to attach? and all that other good stuff i should know?
Thanx in advance to anyone who responds!!!!
Old 11-16-2006, 05:00 PM
I would suggest checking with an auto parts or tool supplier for a 5 gallon portable tank and just put it inline with the compressor. You will need to pick up a regulator also but most any of the inexpensive import type should work fine for this. This is of course assuming the compressor is capable of greater pressure than the airbrush requires.
Old 11-24-2006, 04:52 PM
pigjamelectric's Avatar
oldsmobile compatible
Last wiki edit: Selling your car Last photo:
Wiki Edits: 29
I see you're from Canada. Princess Auto would have all you need to set you up with a tank. Or you might consider just getting the Revy combo deal of pancake compressor and Brad nailer. Build wooden boxes with the nailer and then airbrush them. Although I don't know if the Revy compressor would be able to supply you with enough air for airbrushing.
Paul.
larger compressor gburgess2002 Garage - Tools 13 07-19-2009 09:36 AM
shooting clear vinvango73 Body - Exterior 3 10-28-2005 11:24 PM
Crappy Air Compressor Wont work rbfpezcore Garage - Tools 7 06-12-2005 02:24 PM
Adding 2nd air tank to compressor cboy Garage - Tools 7 10-26-2004 10:17 PM
Anyone Looking For An Air Compressor ?????? STATUTORY GRAPE Body - Exterior 2 07-14-2003 06:24 PM
