need help bad with wiring please - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-09-2011, 04:11 PM
hddave1's Avatar
hey guys.. i got problems trying to wire my 302v8..here is what the problem is, the ignition coil is getting so hot that you cant touch it and the red pos. and green tach wires are melting...here is what i got..STARTER RELAY(mounts on the passenger side fender) has a wire that is hot only with the key in the start position, has no power in the run position(runs the starter)...
... ok..COIL .. has 2 wires 1 green (tach) and 1 red(pos+) the green is tied to the green on the ignition module.. the red wire is tied to the white wire on the module and also tied to a hot(that is hot in start and run)...
.. IGNITION MODULE.. the red wire is tied to a hot (only hot in run no power in start) ... with it hooked up the way it is, i can turn the key to start and the engine cranks and i have spark from the sparkplugs ( weak looking spark but there is spark) ... i am working on a 85 ranger that i put a 80's year 302... what did i do wrong and how should i wire the engine..guys i have 2 full days at this and im lost...cant figure why the coil is getting so hot...
Old 03-09-2011, 06:21 PM
I have a schematic for the 1980's Ford Ignition Module but I know these changed somewhere in the middish 1980's so if this exactly fits yours I don't know. You will see that all power to the coil goes through a ballast resistor start and run. This probably means the coil runs on 9 rather than 12 volts. See the attached file.
Bogie
Old 03-09-2011, 08:09 PM
hddave1's Avatar
ok i can buy that...now im gonna assume the 85 ranger did not have a ballest..so where can i get one and where does it go...this thing is kicking my but and i can get it running till i get past this..
Old 03-10-2011, 07:08 AM
hddave1's Avatar
anyone???..
Old 03-10-2011, 07:59 AM
delawarebill's Avatar
balllast resistor
go to any auto parts, they carry them..
Old 03-10-2011, 08:25 AM
hddave1's Avatar
ok i can get a univeral ballest resistor at a parts store...can you tell me how i wire the thing up...also does the red wire from the round coil get its power from the run only or does it have power in the start and run...thanks
Old 03-10-2011, 12:21 PM
It's an external resistor, you should be able to get one at the Ford store and probably better equipped independant parts stores. Here's diagram of how it wires.
Bogie
File Type: doc 1980's Ford Ballast Resistor Schematic.doc (206.0 KB, 84 views)
Old 03-10-2011, 08:53 PM
hddave1's Avatar
Bogie
wired it up with a ballest resistor like you showed me and it started right up. coil dont get hot..thanks
Old 03-10-2011, 09:30 PM
Good deal, glad it's working.
Bogie
Old 03-11-2011, 07:31 AM
ballast resistor
dave good... u were sending 12v to the coil when it wanted something lower.. i burned out my pertronix by puttnig in a zero resistance coil... my old coil have about 2 ohms.. Oh well $80 bucks down the drain...
wiring fordhotrod Electrical 0 10-02-2009 09:18 PM
EZ wiring - back up light wiring copdwg Electrical 3 06-07-2008 07:42 PM
Need wiring help! truckcat Electrical 3 04-23-2006 05:37 PM
s10 wiring krausman Electrical 3 04-08-2003 01:13 PM
rs wiring 67rscamaro Electrical 2 02-18-2003 06:59 PM
