Need help on a block
Hello all,
I have a block that I am wanting to use on a project that I'm working on. I got the block from a friend and he slung a rod thru the oil pan. To make a long story short there is a chip in one of the cylinder walls very low on the cylinder where the rod made contact when it let go. I don't know if there are any cracks because it hasn't been to the machine shop yet. I just want to know if it will be worth taking it to the shop to get worked on or find another block. Thanks for any help |
What kind of block? Some are "worth" repairs, others are easier to replace. A pic of the damage would help, too.
Jim |
Take it to the machine shop and have them magnaflux it. If it's not cracked and not in the ring travel area they can deburr it. I had a 350 with a nearly identical chunk missing and once it was cleaned up I rebuilt the engine and drove it for 10 years before I sold the truck I put it in.
There is a picture, its a 350 block don't know if its anything special or not.
Thanks for the info, it looks like it will be ok to use I just wanted to get some feedback from someone before I take it to the machine shop.
Thanks again. |
The machine shop is the only one who can really tell you if it's good or not. Take it to them and they will give you a yea or nay.
Just for the heck of it, post the casting numbers
Check out my block stuff here.. well, there's other stuff too.. http://s28.photobucket.com/albums/c2...t=MOV01672.mp4 |
Block
Take it to the machine shop and have it checked for cracks. If OK you can have a sleeve installed in that cylinder for peace of mind. I have had blocks sleeved before and haven't had any problems.
| Big block pil pump on small block Chevy | dallam11 | Engine | 22 | 03-24-2012 07:36 PM |
| small block to big block swap in a 91 camaro help! | Greg O Sandsten | Engine | 6 | 11-02-2010 11:02 AM |
| Long block short block fitted block what do | opelitis5 | Hotrodding Basics | 4 | 01-10-2010 06:12 PM |
| Need advise for trade. 408 short block for dart iron eagle block | sherman8r | Engine | 6 | 12-06-2009 04:37 PM |
| Big block water pump on small block! | TVR383 | Engine | 14 | 04-15-2008 07:43 AM |
