need help with blower pistons - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-18-2007, 12:26 PM
malibu68's Avatar
i have a 383 block, well 95-2000 1 peice rear 4 bolt main that has been machined and clearenced. with a 671 wieand
crank:Crankshaft, 1-Piece Seal, External Balance, Cast Steel, 3.750 Stroke, 5.700 Rod
rods:Connecting Rods, 4340, I-Beam, Cap Screw, 12-Point, 5.700 in
the heads are goin to be either 64 or 68 cc
there are 3 pistons i have been looking at:
UEM-KB735030-8 Pistons, Forged, Dish Top, 4.030 in. Bore, 1/16 in., 1/16 in., 3/16 in. Ring Grooves,
UEM-9926030-8 Pistons, Forged, Dish Top, 4.030 in. Bore, 5/64 in., 5/64 in., 3/16 in. Ring Grooves
SRP-148750 Pistons, Forged, Dish Top, 4.030 in. Bore, 1/16 in., 1/16 in., 3/16 in. Ring Grooves
so the real difference is that the 2 keith blacks are an 18 cc dish and the srp is a 24 cc dish the one keith and the srp both use a 1/16 ring but the cheapest keith uses a 5/64
so is it better to have a thicker ring when in a blower motor>?
which is the best choice
Old 01-19-2007, 08:15 PM
malibu68's Avatar
does anyone know if it is better to have thicker pistons rings with a blower motor or not? is there any drawbacks or advantages?
Old 01-19-2007, 08:28 PM
malibu68,
If you were going to race this engine then the smaller ring would weigh a little less so you might get a few more RPM's. I think the smaller rings would cause less friction but again in a street engine I do not think you would be able to feel the difference.
Scholman
Old 01-19-2007, 10:32 PM
techinspector1's Avatar
Wiki Edits: 326
I'd run the thicker rings in a blower motor for a better seal at the expense of a little more friction.
Blower pistons malibu68 Engine 15 12-14-2006 08:49 PM
blower je pistons, nitrous capacity? 84Z Engine 11 08-31-2006 01:23 AM
blower pistons ??? singletoncamaro69 Engine 9 04-02-2004 08:02 AM
Engine, Blower, Heads, Pistons, Distrib., and more 84Z Engine 0 12-21-2003 10:58 PM
ENGINE, Blower, Pistons, Heads, Carb, Distributor, and more 84Z Hotrodders' Lounge 0 12-21-2003 10:54 PM
