Need help with Brakes
I have a 48 Ford that has a Mustang II front end with disk brales. It has a Granada rear end with drum brakes. I have a under floorboard power break mastercylender for a corvette. I have 2 check valves and a ajustable valve for the back brakes. I dont think I have any air left in my lines, My check valves seem to work and are in proper position. I cant find any leaks, I seem to have good vacumn to the booster. I have a solid peddle, but the brakes will not hardly stop. I have tried 3 new mastercylenders, and 3 new boosters. Sometime you can get enough brakes to slide and go bach a day or so later and It want hardly stop again. I have spent months working on these brakes. Can anyone help.
Corvette MC? You do know that Corvettes came with 4 wheel DISK brakes right?
And you have drum brakes on the rear. Taint gonna work. Get a MC that is designed to use drum /disk and make sure you have the right MC bore diameter for the front disks. This will take some research, or maybe a call to Speedway's tech line |
| disk brakes conversion no pressure to back brakes | shiner | Suspension - Brakes - Steering | 10 | 01-24-2011 11:09 AM |
| Need Help With My Brakes | S10 Racer | Suspension - Brakes - Steering | 4 | 01-18-2009 02:00 PM |
| Hotrodders Knowledge Base: Suspension - Brakes - Steering | Jon | Suspension - Brakes - Steering | 0 | 11-26-2005 06:29 PM |
| G body with manual brakes - it works! - pics | dh79 | Suspension - Brakes - Steering | 7 | 08-27-2005 10:55 PM |
| Brakes locking up in non ABS system | nprfan | Suspension - Brakes - Steering | 9 | 08-24-2005 12:37 PM |
