need help with buddies 355 sbc timing!!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-19-2012, 08:02 PM
350vortec's Avatar
my buddies got a 355 sbc that is being a pain to time, its idling around 950 and about 600-700 in gear, right now with a 700r4 and a stock stall converter until he can afford a 2800+ (hes not driving it anywhere yet just setting it up) every time i get it to advance past 0-4* BTDC it stalls out but runs pretty good when its retarded more then 0- 15* AFDC, does this make any sense??
its got cast dart angle plug heads (unsure of which ones) with a vic jr intake 600 cfm edelbrock carb, and a solid flat tappet cam xe282s 244/252 degrees duration at 0.050 inch tappet lift, it has 0.520/0.540 inch max lift, and is ground on 110 center.
can someone please shed some light on this!!??
Old 05-19-2012, 09:39 PM
68NovaSS's Avatar
Moderator
Wiki Edits: 9
Do you have the correct timing cover and timing pointer? GM made several with different pointer locations. Have you verified TDC and the damper markings?
Semper Fi
Old 05-19-2012, 10:09 PM
350vortec's Avatar
Ya we bumped the crank over with the starter with #1 plug out to feel for compression and turn tell tdc by hand and the mark on the balancer is lined right up with 0.
Would a to rich mix fuel mixture cause this? When we have it set at 0* with vacuum advance hooked up to manifold vacuum, it runs pretty good but is also hard to start. when starting with it set at 0 we had to have WOT in order for it to eventually fire then it ran good after it started. A little poping out the exhaust after we hit the gas harder and let off. I'm a lil boggled here of what's going on
Old 05-19-2012, 11:15 PM
DoubleVision's Avatar
There's no doubt it's off at the balancer. The balancer could have spun which is common on older small blocks. I have NEVER seen a small block with a carb that would run with retarded spark timing.
Old 05-20-2012, 06:45 AM
Use a piston stop tool to determine tdc.
That cam requires a 3000 rpm stall converter.
A cam that size will need 20-25 degrees at idle and 36 to 38 total. And another 10 from the vacuum advance (if the engine can make enough vacuum). Also, setup idle at 1000 rpm.
Old 05-20-2012, 11:30 AM
Blazin72's Avatar
You got a leaky spark tube...
Last wiki edit: Rearend removal
Last journal entry: General Lee
Wiki Edits: 19
That isn't an accurate way to check TDC. As a slightly different example, I recently finished replacing a cylinder and head on an ATV without correctly locking the crank in place. Instead, I tried turning the crank by putting the transmission in 5th gear and turning the tires. I thought I had the engine locked in the right place then installed the cam and reassembled the chain. After it was all back together it wouldn't even crank over when it came up on the compression stroke. Everything "looked" correct but it wouldn't run. I ended up pulling the cam cover back off and lined up the crank using the correct method and sure enough I had the cam one tooth advanced. It runs great now that I did the job correctly.
The moral of my story is that doing things the easy or the quick way isn't always the right way.
First disconnect and plug the vacuum advance then recheck your timing and go from there.
Then you may need to find actual #1 TDC compression without relying on or even looking at the current timing tab and balancer. Doing so can definitely skew your judgement and you'll trick yourself into thinking you're getting it right. Once you know exactly where TDC is then look down and see if your timing marks line up like they are supposed to. It is entirely possible that the tab and/or balancer are not correct.
Setting timing by ear is not a good idea either.
Old 05-23-2012, 11:20 AM
350vortec's Avatar
Hey thanks guys for the replies, I just ordered the spark plug piston stop from summit so when it gets here ill try to find true tdc and go from there. Is there a proper procedure to using this kind of piston stop? Thanks
Old 05-23-2012, 12:38 PM
350vortec's Avatar
Ok thanks, is loosening the valves a must? Would it work to just screw in the piston stop on the compression stroke and then turn it over, mark, turn it back a tad, unscrew it and then turn the engine back untill the piston is close to tdc again then screw it back in and turn it tell it touches?
Old 05-23-2012, 02:20 PM
350vortec's Avatar
No I don't need help with resetting rockers or anything. I've done all that a # of times, I've just never used a piston stop before so I was just simply asking for my on curiosity. I got no prob backing off the rockers I just wanted to know if it was a MUST, seeing as it sounds that way, I WILL back them off and do it as u first said. Btw thanks for the help
Old 05-23-2012, 08:20 PM
cool rockin daddy's Avatar
Just use the piston stop you ordered. You don't want to cobble one up with "an old spark plug with a pipe welded to it" if you've never used one before. sheesh.
Old 05-23-2012, 09:02 PM
I recommend to pull ALL the spark plugs so the engine turns over easy.
insert the tool into #1 cylinder then turn the engine over slowly and easily by hand until the piston hits the tool. Mark the balancer at the tdc mark on the timing chain cover
Spin the engine over the OTHER direction until the piston stops again. Mark the balancer again at the tdc mark on the timing chain cover.
the center point between the 2 marks is TDC.
Low buck 355 sbc not running correctly, wanting to much timing. ForceFed86 Engine 67 04-13-2011 12:35 PM
355 sbc timing help schottout Engine 1 12-11-2009 10:37 PM
SBC 355 Timing Question Fasazu Engine 7 10-16-2009 08:59 PM
SBC 355 Timing Question Fasazu Engine 1 10-14-2009 09:43 PM
355 update and timing question. Jared Engine 4 06-04-2003 04:26 AM
